So I have removed my rear and front wheels for bearing replacement and powder coating. In trying to replace the bearings, all of the literature and information online shows an inner spacer sleeve ...With two halo type washer/spacers integral on the sleeve which create a washer type separation from the outer sleeve. On my 1978 snowflake wheel my inner sleeve is blank… there are no halo washers in its circumference but was simply a rubber slipon washer. there are no integral washer type spacers to prevent it from free floating on the axle, inside of the outer spacer sleeve. I cannot get an appropriate stack as there is a significant (approximately 1/4 inch) gap between the outer sleeve and the face of the bearing races. I am really confused and don’t know if someone installed an improper part prior to my purchase of the bike or if I’m doing something wrong. All of the books and videos I have referenced show the stack with the inner and out sleeve.
I need some help please!
