nevada72
Vintage User
To clarify, my motor is leaking like a sieve and I plan to pull it this winter and replace all the gaskets. In fact, the whole bike needs a really thorough going over and refresh. It's been a rider for the last 35 years. But it's a nice running riding bike, so no obvious mechanical issues. Always starts, and purrs along beautifully.
Here's the loose plan so far - (keep in mind, I'm a shade tree mechanic. I've been wrenching on bikes for decades and know enough to get by, but no real BMW specific skills other than the basics, valve adjust, clutch adjust, etc)
Pull motor/trans, pull heads and ship off to have the valves converted to unleaded.
Take engine apart to replace all soft gaskets - especially the oil pan gasket. It's leaking a lot. All the other seams show signs of weeping.
Sympathetically clean everything up. Not trying to make the motor look new - just get rid of the oxidation and grime.
Take a hard look at the clutch and rear main seal. I'm guessing the seal needs to be replaced and the clutch may need to be reworked - take up is at the very last millimeter of the lever. I've had to adjust it to keep it from slipping but I think I'm running out of adjustment - not 100% sure.
So really, I'm wondering about the pitfalls of disassembly as well as the while your in there's of a motor with 40k miles on it.
I'm also wondering if there is a Go-To gasket kit, like from Bob's. I'll call and ask.
Any and all feedback appreciated.
