Results 16 to 21 of 21
Thread: Mini Air Compressor
    Quote Originally Posted by lasnin View Post
    This unit saved my bacon when I got a flat on the rear tire on my RT in the middle of nowhere in Southern Oregon. [URL="http://https://www.rockycreekdesigns.com/collections/tyre/products/motopressor-mini-pump"]
    404 Not Found
    Debbie's Servant Lee's Avatar
    SW Iowa
    404 Not Found
    Try this
    https://www.rockycreekdesigns.com/pr...ssor-mini-pump
    Lee
    2016 R1200RS
    MOA # 30878
    Thanks Lee
    Registered User lasnin's Avatar
    Jul 2017
    Susanville, California
    Motopressor mini pump
    Sorry for the messed up link... however I also have the 12v adaptor pin to be able to plug the unit right into the onboard BMW outlet... very easy and slick.... saves me trips to the gas station to top off tires..
    Knight-Errant 1957mpd's Avatar
    Feb 2018
    Las Cruces,NM
    At home, I just use my bicycle pump. Designed to put 120 lbs into my road bike tires, the 42 lbs in the rear and 36 in the front on the BMW's tires is no challenge for it at all. Harder was finding one with a 90-degree chuck that could deal with the spokes on the GSA.
    "Solů el que ensaya lo absurdo es capaz de conquistar lo imposible." Miguel de Unamuno 1905
    Mark - Las Cruces, NM - '10 K1300S and '17 R1200 GSA
    Quote Originally Posted by 1957mpd View Post
    At home I use my 30 gallon Craftsman air compressor. I do change my own tires and little pumps and especially hand pumps make seating a tubeless tire bead a bit difficult.
  1. CO2 cartridges or air compressor?
    By utahskies in forum Gear
    Last Post: 09-27-2016, 12:58 PM
  2. Mini Air Compressor
    By lgb in forum Gear
    Last Post: 07-27-2013, 09:49 PM
  3. Air compressor
    By PineGreen in forum Gear
    Last Post: 03-02-2012, 11:15 PM
