Moto316
Member
I changed my oil recently and I noticed a small drop on the floor after a few rides. Upon inspection it looks like the crush washer is the culprit. I torqued the bolt as per the specs when I changed the oil. I gave the bolt an extra eighth turn but it is still dripping a little after yesterdays ride. So, it's time to drop the oil and change the washer.
Not to start an oil thread and get permanently expelled from the forum, my question is; is it safe to clean my drain pan real well and reuse the oil? Would I need to filter it somehow before putting it back in the bike? Or should I just not be a cheap sob and spend the $100 and buy new oil? The oil only has a couple hundred miles on it.
