Results 1 to 9 of 9
Thread: wiring for rear auxilliary brake and running lights
    Apr 2004
    Wisconsin
    I'm going to try hooking up some small LEDs for the rear of my 2016 F 700 GS to increase my rear visibility. Is it okay to simply tap into the existing brake and running leads? Are there two separate leads for these functions? I know brown is ground, but does anyone know what the colors are for brake and running light leads? Thanks!
    Lanark County near Ottawa ON
    Quote Originally Posted by devo View Post
    The brake and running light leads are one in the same because the same LEDs in the taillight perform both functions. The bike's ZFE pulse width modulates the LEDs to make them appear dim for running and brighter when braking.
    Mansfield,MA
    I think you are going to need a bike specific kit for the reasons the post above mentioned. Skeen Design has some ideas IIRC.
    oM
    Mod Squad
    2009 F800GS 1994 TW200
    Hex?
    Hezezcan is supported now on the F800 series so I would send them an email and see if they thought it might work on a 700, since they are very similar (I would guess "yes".) Very easy way to add electrical circuits.
    https://hexezcan.com/
    Apr 2004
    Wisconsin
    hezcam or other CANbus interface not needed for aux brake lights
    FYI: Contrary to popular belief, a CANopener, Hezcan or other CANbus doohinky is not needed to just add auxiliary brake/running lights to F700GS (2016). A Clearwater Lights tech showed me how their "Billie Light Jr. can be added for rearward conspicuity, simply by Posi-tapping into two leads under the seat. Works like a charm; however, the same can not be said for the R 1200 or 1250 GS.
    Aug 2018
    Fargo, ND
    If you are running LEDs there is a good possibility you can wire them in directly.
    I just got my 2018 R1200RT set up to pull a Unigo trailer. I put LEDs in the trailer and wired it directly into the RT's tail and turn lights. It works fine.
    True, but I hate cutting into OEM wiring harness. Introduces a weak point in the wiring and if you want to sell on, looks messy and crude.
    Slow/Look/Press/ROLL! DBCasey's Avatar
    Sep 2010
    Frankfort, Kentucky
    Looking at my Haynes Service and Repair Manual F Twins(06-16 F650,700,800):
    Tail lights are Gray/Yellow/Red,
    Brake lights are Gray/Yellow/Black.
    LH Rear Turn signal Blue/Red/White
    RH Rear Turn signal Blue/Black/White
    License Plate Light Blue/Gray/Yellow
    If you'd like pics of the wiring diagram, PM me.
    Happy wiring!
    Daryl
    Daryl Casey
    Frankfort, KY
    Thank a teacher if you can read this, thank a veteran that it's in English.
    Sep 2009
    Chestnut Hill, MA
    Skene Design has some very good solutions for increased visibility, front and rear: https://www.skenelights.com
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    Watching the sunrise outdoors statistically increases your odds of having a good day. And needing a nap after lunch.
  1. R1150R auxilliary lights
    By TonysR100 in forum Oilheads
    Last Post: 06-19-2013, 02:08 AM
  2. R90 wiring extra brake lights
    By plehman in forum Airheads
    Last Post: 01-31-2013, 12:39 PM
  3. Brightest Running and Brake Lights - '95 K75A
    By GREGFUESS in forum Flying Brick K-bikes
    Last Post: 01-26-2011, 08:12 PM
  4. Add running, brake, and tail lights to your RT
    By ArthurKnowles in forum Oilheads
    Last Post: 06-11-2008, 05:12 AM
  5. Replies: 9
    Last Post: 04-07-2007, 07:06 AM
