Results 1 to 9 of 9
Thread: Alternative GPS mount
    I have been considering adding a RAM ball to the snap in dust cover over the GPS mount on my 2018 RT. Has anyone tried this? It looks like I can drill holes through the cover and not encroach on the protective ring around the bikes electronic plugin.
    I will not own a Garmin GPS again after my last expensive experience. My plan is to use my Iphone with one of several GPS apps that I have.
    Wills Point, TX
    I think a better option is RAMŽ Motorcycle Brake/Clutch Reservoir Ball Base Part# RAM-B-309-1U - please double check the thread
    Jay
    Quote Originally Posted by strataj View Post
    Jay
    I have one of those already. I will be installing the Ilium risers this weekend and may end up doing something different anyway. The only reason I am considering this is to get my phone in my direct eye line and hopefully a little less refection from the sun.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Consider removing the GPS mount from the bar and replacing it with a a mount specifically made for a smart phone. Cleaner look and likely more durable than using the dust cover. I have not looked, but I suspect that the GPS sub-harness plugs in somewhere that you can access without too much work.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Registered User dlong's Avatar
    Jul 2014
    Sedona AZ
    This setup works for me. A hard shell case and industrial strength hook-and-loop adhesive material are all you need. Take care not to mount the case too high, as there will be conflict with the charging cable. Using Google Maps continuously, I find the phone will very slowly discharge but still allow 400-500 miles of use. The charge cable runs to the USB cable in the R storage pocket. I purchased a new dust cover for about twelve bucks to clean up the appearance of the dash when not using the iphone Google Maps setup.
    Quote Originally Posted by dlong View Post
    I like your idea. I have done this with a garage door opener on another bike. The phone is a bit heavier and I thought it might not hold. That and I have found that Velcro doesn't always like the heat and the glue softens up. Any problems with that yet?
    Jul 2014
    Sedona AZ
    I've only used this on one 2k ride. The iphone/case combination is very light and doesn't put much stress on the velcro or adhesive. I did use a product advertised as maximum strength and not really suitable for applications which require frequent separation of the hook and loop material. It requires some effort to detach the case from the dust cover, and even more to peel the velcro from any smooth and hard surface. I didn't fell it necessary, but some sort of retention system could easily be placed using a zip tie.
    Registered User bobsguns's Avatar
    Mar 2018
    SE TN
    Quote Originally Posted by lstayner View Post
    Can I get the cliff note version on the Garmin issues, please? I've got 3 of them & they've all done well for me.
    Quote Originally Posted by bobsguns View Post
    I got a Garmin motorcycle GPS for Christmas. I mounted the permanent cradle and wired it up the way it is supposed to be. The GPS wouldn't maintain a charge for more than a couple of hours no matter what I did. I contacted Garmin and they had me send it in for repair. I received the refurbished unit and the same problem existed. The unit I have has the "head of a pin" electrical contacts for electrical contact. I triple checked them to make sure they were making contact. After working on it several times, I gave up in frustration. When you pay over $700 for a unit that is designed so poorly, it makes you think again before you buy the brand.
    I have used my Iphone for several trips and have decided that it works as well as the Garmin unit did. I have a bluetooth dongle attached to the bike AUX input and listen to directions through the speakers. I haven't had any success connecting a phone to my Sena bluetooth helmet intercom. My wife and I keep the intercom channel open all the time for conversation and the GPS tends to lock up the Sena after a couple of GPS directions. Having to shut down the Sena units and restart are a pain in the behind.
    If I go to a stand alone GPS, it will be a TomTom motorcycle unit. 95% of the time I have my route memorized or written down for quick reference on the bike anyway.
  1. Cell Phone mount and Garmin mount for 96 R1100RT
    By oldcarman in forum Oilheads
    Last Post: 09-13-2018, 05:57 PM
  2. Replies: 8
    Last Post: 06-02-2017, 02:11 PM
  3. Looking for an alternative
    By 157149 in forum Motorrad
    Last Post: 06-05-2014, 08:52 PM
  4. Replies: 2
    Last Post: 03-06-2012, 04:11 PM
  5. R1200R - alternative GPS mount
    By deilenberger in forum Hexheads/Camheads
    Last Post: 08-23-2007, 05:37 PM
