Results 1 to 12 of 12
Thread: Front brake light switch
    Is there an alternative to the $60 switch that threads in the brake lever perch R75/5 ? Mine was missing from PO.
    Liaison 20774's Avatar
    From IBMWR site, look for any air cooled VW two-pronged brake switches. The site says early water cooled VWs with 3-pronged switches could work, just find the two that are normally open.
    Nov 2009
    Ontario, Canada
    Mine just went as well on the 71 R60/5. $ 90 canadian. i replaced the same switch on my 1981 R100cs ( looks similar) for $ 15.00, I wonder if the threads are the same... the length would have to work as well.
    Louie..._/)....
    Louie -
    Do you have the part number for the '81 switch?
    61 31 1 244 070 is the part #. I saw this and wondered the same thing. The R75 threads are fine M8, probably 1.75.
    The VW switches are for a hydraulic system.
    That part number is only used on BMWs from the late 1970s-on...as an example, it's #24 on this picture:
    https://www.realoem.com/bmw/enUS/sho...47#61311244070
    Now look at this picture of the right hand controls for a '70 R75/5 (which I believe you have):
    https://www.realoem.com/bmw/enUS/sho...diagId=32_0752
    No such part is shown for the /5. I'm not sure what switch we're talking about...can't seem to find it. You have a drum brake...the part number 61311244070 is used on bikes with hydraulic brakes.
    Hmmm, This part no was on ebay when I enter "airhead brake light switch".
    Is this what the switch is supposed to look like? This is from Duane's website:
    https://w6rec.com/duane/bmw/control/control33.jpg
    Yes, the R75 one looks like that. It has that specific locknut.
    I went to an auto parts store and the automotive ones are too large in diameter at the threaded portion.
    This R75/5 that I bought from the PO had a lot of missing parts (not to mention the dented leaking RH valve cover) and the parts total is adding up. The bike is now starting fine and coming together.
    Part number is 61 31 1 351 662:
    http://www.realoem.com/bmw/enUS/show...24#61311351662
    It was also used on the late model /2 bikes just before 1970.
    Nov 2009
    Ontario, Canada
    The /5 brakelight switch is listed under horn/brakelight switch and is part # 61 31 1351 662
    The 81 R100cs is listed at the right handle bar and is part # 61 31 1 244 070, 6 x 0.70mm thread.
    they look similar but the /5 is silver and much larger.
    Louie..._/)....
    Yup!
    The left hand down in the slow to stop signal as required by most DMV motorcycle riders license test pre-'70, is a cheap and ineffective stop light switch. "Sorry" but I saw this post at a time when I just can't contain my "what do you expect" attitude. That particular brake light switch was available for a couple years nearly forty years ago and at that time it might have cost 2 0r 3 $s now it cost a little more if you can even get it. $60 is a deal, call me stupid or extravagant but I can't see a problem with paying a bit more for the correct part to make your bike work the way it is supposed to. You will probably spend more time and money with no success trying to make something work.
    After you hunt the internet and all the auction sites for the switch (incorrect or not) think about the time an money you spent trying to save a few bucks for the best deal when you could have paid a little more, got an assurance of a correct part and a guarantee of a working part, $3 forty years ago and $60 now, I guess I might thank the supplier for holding onto that obsolete switch for the last 20 years
    I'm not rich or anything but I do a lot of antique, vintage and modern BMW bike stuff and find that sometimes the parts needed for a correct repair are very expensive and may even seem obscene to some extent but if you need it and really want to keep it simple you have to pay the price.
    Sorry but the tone of the OP just got under my skin a little. Spend 3 hours on the web and another 2 trying to make the wrong part work and you will understand.
    Zeff
  1. Replies: 5
    Last Post: 07-17-2015, 03:30 PM
  2. Replies: 28
    Last Post: 04-16-2014, 12:26 PM
  3. Front brake light switch
    By DEANCOX in forum Flying Brick K-bikes
    Last Post: 02-28-2007, 09:11 PM
  4. K100RS Brake Light, Warning light and Switch headache
    By sgtbill in forum Flying Brick K-bikes
    Last Post: 11-19-2006, 09:32 PM
  5. R90s front brake, light switch location?
    By 19059 in forum Airheads
    Last Post: 04-14-2006, 10:37 PM
