Page 5 of 5 FirstFirst ... 3 4 5
Results 61 to 74 of 74
Thread: Sticking front wheel
  1. #61
    Aug 2004
    Woodbury, MN
    Next steps
    As I wait for the new parts to arrive, I need to remove the sealing ring that resides inside the caliper and clean the caliper. What is the best method for removing this seal without damaging the caliper? Given the state of the front brakes, I'm wondering if I should more carefully examine the master cylinder? Suggestions on how to proceed will be appreciated.
    rickt
  2. #62
    Liaison 20774's Avatar
    I'd study what Brook has posted here:
    https://brook.reams.me/bmw-motorcycl...ster-cylinder/
    Notice that he uses a pick and carefully grabs the square o-ring and pulls it out of the groove.
  3. #63
    Aug 2004
    Woodbury, MN
    Master cylinder rebuild
    Given that I now have the calipers under repair, Iím thinking that the master cylinder should be carefully examined (rebuild?). The parts fiche shows two repair kits. One for bikes to 09/1975 16mm, the second for bikes from 09/1975 17mm. My R90S is 1975. Is there any way for me to determine which kit is correct for my bike without taking the MC off and apart?
    rickt
  4. #64
    Did you look at the link I posted? Brook documents how to tell what size master cylinder you have...it's stamped on the body of the part.
  5. #65
    Aug 2004
    Woodbury, MN
    My bad
    I did quickly read through the article. Obviously I did not pay close enough attention to the details.
    rickt
  6. #66
    Motorsickle Rider brisco's Avatar
    Oct 2010
    De Soto, KS
    I see several single 40mm calipers on eBay. Various prices. https://www.ebay.com/itm/76-BMW-R100...QAAOSwPEdc1NR7 is one, there are more. I searched for bmw 40mm caliper r90s
    Good luck!
    Brian
    Kansas. Eleven curves in three hundred eighteen miles...
    '09 R1200RT, '70 R75/5, '73 R75/5, '11 Ural Patrol
    N0PGH
    Iron Butt Assoc. #47865
  7. #67
    Aug 2004
    Woodbury, MN
    MC Repair Kit
    I managed to remove the MC from the bike frame. The exterior will need to be cleaned and painted. Examination of the piston with a caliper indicated a diameter of 17.43 mm. There are two MC repair kits listed on microfiche. Part # 34 31 1234925 for D=16 mm and part # 34 31 1234927 for D=17 mm. There is no size marking on the outside of the MC. Can I assume that the 17 mm repair kit is correct for my R90S?
    rickt
  8. #68
    You should have seen a number in the casting like Brook shows here:
    https://www.flickr.com/photos/brook-...7675789624605/
  9. #69
    Aug 2004
    Woodbury, MN
    This is how I am reminded
    Being reminded of my mental deficiencies happens much too frequently. Indeed the 17 was right on the casting where it is supposed to be. Onward I go.
    rickt
  10. #70
    Aug 2004
    Woodbury, MN
    Update and A New Issue
    As suggested, I did find a 40mm caliper on Ebay. I painted all three calipers and the MC with black epoxy and ordered a second 40mm caliper rebuild kit. I decided to rebuild the MC and ordered the appropriate kit. Now, another case of memory failure. I misplaced/lost the MC fluid container, cap and allen screw that holds it to the MC. I typically put all parts in a zip-lock bag for safe keeping but it was no where to be found. I called Bob's and ordered a new fluid container. After some further investigation, I determined that the allen screw that is used to attach the fluid container to the MC is not available. The flanged screw/bolt appears by my guessing to be thread 1.0 and 10-11 mm in width. Any suggestions where I might find this part or anyone who may have a spare would be greatly appreciated.
    rickt
  11. #71
    [QUOTE=r65lsk75c;1176894 Any suggestions where I might find this part or anyone who may have a spare would be greatly appreciated.
    rickt[/QUOTE]
    Youíre into this resuscitation a bit, but if/when you decide you want professional mechanical help (or a source for parts), youíre lucky to have Charlie Johnson, an excellent airhead mechanic, not far away in Wayzata, MN. (952) 449-0357.
  12. #72
    Aug 2004
    Woodbury, MN
    Getting past the frustration
    As suggested I made the 50 min. drive to Charlie Johnson's shop in Victoria. He did have the proper allen-head screw for mounting the fluid reservoir to the master cylinder. The MC is now securely strapped to the top of the bike frame. Now I will venture onto the assembly of the calipers while hoping for no undesirable setbacks.
    rickt
  13. #73
    Aug 2004
    Woodbury, MN
    Inserting Pistons into Calipers
    I'm guessing that I am displaying a high degree of incompetence. Everything is clean and following the procedure outlined in Brook Reams notebook I cannot get the piston to enter the caliper. No amount of juggling, pushing or attempting to turn the piston was successful. I lubed the side of the piston and the seal with
    brake fluid as suggested. I am reasonably certain that the piston is aligned correctly. Am I missing something? Are there other means of making the piston cooperate? Is the use of a C-clamp to push the piston in totally inappropriate? Any suggestions will be appreciated.
    rickt
  14. #74
    Quote Originally Posted by r65lsk75c View Post
    rickt
    Not incompetence; it's the experience I had. Get some red rubber grease. https://www.ebay.com/itm/20g-Genuine...oAAOSwZrhaeH-L It is not typically available locally (at least around me). I learned about it reading Brit bike magazines. Every year or so thay'd have an article on rebuilding calipers. And every one used red grease.
    I have used a c-clamp and it didn't seem to cause much damage but the grease is the way to go.
    '61 Clubman's Gold Star, '13 690 Duke, '13 Daytona 675R, '17 1290 GT, '18 Street Triple RS (gone but not forgotten: '76 R75/6, '84 R100, '76 R90S)
  1. Replies: 15
    Last Post: 03-25-2016, 02:54 PM
  2. 2001 K1200rs front brake sticking on
    By hogsback15 in forum Flying Brick K-bikes
    Last Post: 11-05-2015, 11:48 AM
  3. 98 R1100RT Sticking front brake lever
    By rtwoody in forum Oilheads
    Last Post: 09-14-2013, 11:52 AM
  4. Replies: 14
    Last Post: 04-26-2013, 11:13 AM
  5. Front Brake sticking
    By r1150gsp in forum Oilheads
    Last Post: 05-24-2008, 04:33 AM
