Results 1 to 5 of 5
Thread: engine coolant level
    I did my 18,000 mile service yesterday on my 16 rt. I checked my coolant level and noticed it was low so I filled it to where it needed to be.
    5 months ago when I did the 12,000 I had the same issue. I haven't had any problems with the bike overheating, didn't see any coolant in the
    oil when I changed it, haven't seen any coming out of the weep hole. Was wondering if anybody else has had to keep an eye on their coolant levels.
    Thanks in advance for your replies.
    Registered User LFarling's Avatar
    Oct 2016
    Harrisburg, PA
    I topped off my 15 RT twice before I got the GS.
    Only talking a few ounces overall I really did not stress over it at all.
    12K on the GS and it has not used a drop.
    I wonder myself where it may have gone and a UOA showed none in the oil and I never say anything from the weep hole, which n the 15 was just a hole. Now there is a hose on them running to under the side stand. So if it over heated you should see something wet there I would think.
    Be nice if someone comes along to splain things.
    Lee
    2017.5 R 1200 GSW
    Registered User beemermyke's Avatar
    Richmond Hill, Georgia
    It's funny how the weep hole seepage issue went from "replace the water pump!" to "add a drain line so it doesn't get on the pretty black engine!"
    Motorcycling is my passion because golf is far too dangerous!
    2016 R1200GSW
    Quote Originally Posted by beemermyke View Post
    Not a surprise. The owners of new bikes can be a bit hysterical sometimes when they perceive that their new motorcycle isn't perfectly perfect perfection.
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    My 2016 needed a top up from "min" to "max" at about 2500 miles - that required 2 oz of coolant mix (50/50 coolant/distilled water). That was mid summer 2017 and I occasionally saw some evidence of dripping out of the weep hole.
    I topped it off again around 7500 - 8000 miles mid summer this year, again it took about 2 oz of coolant mix. I've seen less and less evidence of dripping out of the weep hole.
    The level now seems to be sitting pretty close to "max".
    I wouldn't be too concerned unless it really starts losing a lot of coolant quickly.
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
  1. engine oil level 1999 R1100 S
    By spuglisi in forum Oilheads
    Last Post: 12-14-2017, 02:21 PM
  2. reading the airhead engine oil level
    By hotwheels22 in forum Airheads
    Last Post: 08-15-2016, 09:22 PM
  3. coolant
    By JWP in forum Scooters
    Last Post: 06-01-2015, 11:48 PM
  4. Engine Ice Engine Coolant
    By motoedde in forum Flying Brick K-bikes
    Last Post: 10-31-2007, 03:41 PM
  5. coolant
    By 110066 in forum Flying Brick K-bikes
    Last Post: 03-16-2004, 02:54 AM
