I started the bike. The ABS light didn't go off when I started it stayed on while a did a test ride. The brakes felt fine, nothing different from the usual that I could tell.
I had off: fuel tank, seat, panels, front switch pad. I replaced the clutch cable and the air filter. I had the clutch lever off. I re plugged in the fuel tank 4 square plug. Adjusted the handle bar position.
Before starting up, I put a powerlet 2 to 1 splitter in the outlet on the ignition/front panel. I plugged a usb adapter into one of the plugs. Put the Garmin powerlet plug into the second plug, without the Zumo in the mount. I plugged the phone into the usb to charge. I plugged in my Nocco charger in the plug in the rear box. It went up to 100%. Then, it went back to doing its round of tests, checking at 25%, 50, 75 and 100%. I've never seen it do that. Usually, after it gets to 100%, it just stays on.
I started the K75, let it warm up. Nothing different. After take off, the ABS light kept blinking. The brakes felt fine. After returning to the garage, I removed the front switch pad to see if I disturbed the wiring on the ABS switch. It looked ok. Brown and Black wires.
Any suggestions?
Bill
