Results 1 to 4 of 4
Thread: European vs USA version
    Would someone tell me the difference between a 1996 R1100RS European and USA versions?
    Quote Originally Posted by tycham View Post
    One thing is the Euro version does not have a charcoal canister and associated valve and tubing. Also the "cat code plug" (jumper that selects the ECM map from several) is different.
    Registered User AntonLargiader's Avatar
    Jul 2004
    Charlottesville, VA
    I suspect the differences are just emissions (stuff that Paul mentioned) and lighting (reflectors, headlight control, etc.). Country-specific speedometer, of course. On the RS there was a one-piece seat available that I think was mostly a European thing, but I'm not sure if it was all of them. US models tend to get more options than European ones, so you may be more likely to find bikes over there lacking ABS, RID, heated grips and so forth. Things that were technically options here but became pretty standard.
    Anton Largiader 72724
    Tech articles - YouTube
    Virginia Motorrad Werkstatt BMW motorcycle service and repair in central Virginia
    Vancouver, B.C. Canada
    I had a Euro/CDN 96 R1100RT. The RT has the same engine as the RS. On that bike the configuration was a yellow cat code plug and a CO trimpot under the left side of the seat. Also there was NO O2 sensor and a factory installed plug cover was installed on the harness plug for the O2 sensor.
    I would expect the RS would be the same.
  1. New Version of Basecamp (Mac)
    By Jim Rogers in forum Gear
    Last Post: 07-11-2011, 03:56 PM
  2. Michelin 180/55 ZR 17 'B' version
    By lastsix in forum Hexheads/Camheads
    Last Post: 04-20-2011, 06:35 PM
  3. Which version GS911?
    By leadfoot in forum Gear
    Last Post: 03-27-2009, 10:51 PM
  4. Track Day Version II
    By LORAZEPAM in forum Ride Reports
    Last Post: 05-17-2004, 11:44 AM
