Results 1 to 6 of 6
Thread: Spline lube
    Question Spline lube
    Hey guys, it's time to do a spline lube this off season. Central illinois is not condusive, at least for me, to year round riding. I'm going to use the lube from Beemer Boneyard, Gaurd Dog I believe. My question is, is it alright to use the same lube for drive shaft splines and is it necessary to do those splines at the 38000 mark?
    Quote Originally Posted by burnbender View Post
    The driveshaft splines are quite robust. However, corrosion can be an issue so fresh lube is a good idea anytime the shaft is apart.
    Spline lube
    Thanks Paul, between you and GS I have learned a great deal. I was thinking to save time I might just pull the drive train intact. Do you feel an inspection is warrented. After all the bike is nearly 16 years old and has 38000 miles.
    Registered User beemermyke's Avatar
    Richmond Hill, Georgia
    Paul, didn't you suggest a 50/50 mix of Guard Dog and Moly 60?
    Motorcycling is my passion because golf is far too dangerous!
    2016 R1200GSW
    Quote Originally Posted by beemermyke View Post
    No. My home chemistry was a 50-50 mix of Honda Moly 60 and Wurth Sig 3000. The end result was a really sticky paste with about 30% moly by volume. The Guard Dog product was/is also a really sticky paste with 30% moly by volume so with the Guard Dog no mixing is needed.
    Registered User kthflieger's Avatar
    Apr 2011
    Columbia river gorge, Oregon
    Hey Burn - I think the best solution would be to pull the drive train and send the whole thing to Paul....I don't think he has enough to do since it started raining so much in TX!!
    "Wer reitet so spaet durch nacht und wind -es ist der Vater mit seinem Kind" -- Goethe
    R1200RT, F800GS
    '80 GL1100
  1. Replies: 34
    Last Post: 03-28-2013, 12:16 PM
  2. spline lube or not
    By KARSTEN in forum Oilheads
    Last Post: 02-02-2012, 04:05 AM
  3. Spline Lube-Lube question
    By robsara in forum Flying Brick K-bikes
    Last Post: 02-27-2010, 06:39 PM
  4. Spline Lube
    By QUICKDRAW in forum Flying Brick K-bikes
    Last Post: 06-03-2008, 03:02 AM
  5. Spline Lube
    By 76990 in forum Flying Brick K-bikes
    Last Post: 07-15-2003, 05:29 PM
