Results 1 to 10 of 10
Thread: 1977 R100RS Electric Problems
    Aug 2011
    Orlando, Florida
    I push the starter button, nothing no sound no start. I push the starter button again, I smell electric wire burning, and a puff of smoke from the right handle bar switch assembly (turn signal, kill switch, starter switch/button). So I remove the right handle bar switch and the green wire looks burned as does the one next to it. Also, the 3 lower wires look factory, the others look like someone has soldered them, comments?
    So I look inside the headlight bucket and find; 2 burned/partially bare green wires and a totally burned/melted headlight bulb. The 2 green wires, both connect to the circuit board, top right connector tab, labeled "15 U". The one green wire goes into the wire bundle that goes to the right handle bar switch. The other green wire looks to go into the wire bundle that goes up to the keyed ignition switch (not sure though). The headlight bulb is a 100/80W (ahhh who put that in?). And the bulb holder is toast. So the 100/80W bulb is the culprit it seems. Comments pls, plan of attack to resolve?
    Questions:
    Replace or repair handle bar switch, I have fair soldering skills.
    If I repair the switch, what should I do with the melted green wire from the switch that is in the headlight bucket?
    Replace 3 prong bulb holder? Are they BMW specific or generic car/bike holder?
    Maximum bulb wattage?
    thank you for all comments and suggestions and directions. I will check back but this is a big project. Also, many family issues pull on me so my time working on the bike is back burner. Know that I do appreciate and thank you for your help.
    chuck
    Jul 2017
    Bulb OEM is a 60/55w H4 BMW Part 63121354619.
    Dave Hutton '78 R100S (mfg 7/77)
    John D'oh
    Aug 2006
    Close to Fort Worth Texas
    The bulb melt-down is significant but there is possibly a catalyst. There is a factory service bulletin on first year R100RS that indicates the need to install a fuse in the dash clock circuit - these bikes had mechanical clocks which were powered at all times. That was where the problem lay since under specific conditions, (points closed when engine has stopped rotating) key off - un-switched voltage could be distributed to the system. However unlikely it may seem that this could be a problem now, owners back in 1977 reported melted wires, wiring harness's and in a few cases burned-up bikes. Melted bulb though - that's a new one for me anyway. An event like that you might remember if riding at the time however your observations suggest you were unaware of the melted bulb - or it happened as you pressed the starter and you simply didn't notice as the headlight is shrouded after all.
    I did find a 77 RS that had no fuse as original. It had been purchased new, ridden a few times an sat forgotten until 2007.
    I'd look for another switch since there are probably melted wires in the bundle that now connect everything to everything. Also, check the relays by looking for correct continuity.
    If you haven't already, I'd disconnect the battery completely. From here you'll need a self powered test lamp, volt meter or both.
    Another explanation: Bulb ran so hot it melted fusing the high low and ground and melting the wires adjacent to it. Then as resistance went up connections heated up on the start switch which opened primary wiring circuits and caused a cascading electrical failure. Don't know why it stopped.
    Last edited by Na Cl K9; 10-04-2018 at 04:15 PM. Reason: forgot to add the simple explanation...
    John D'oh
    Aug 2011
    Orlando, Florida
    Thank you for the replies, and to continue with NaCl K9 comments. I was outside in the sun and did not notice if the headlight was on. I disconnected the battery right away when the smoke occurred.
    Interesting comment about the bulb melting and shorting and here is why. In the photos you see that the 3-prong bulb holder got hot and melted some. However, the brown, yellow, and white wires from the bulb holder do show signs of heat or melting. At the bottom of the bulb there should be a plastic/or similar material that seals the bulb and connects the internal bulb wires to the external 3 prongs so the bulb can plug into the 3-prong bulb holder.
    The photo of the bottom of the bulb does not show the plastic. It got so hot and was so brittle that it fell apart when I tried to pull the bulb out. Sounds and looks like a short occurred right at the base of the bulb, doesn't it? Does anyone know what the "15U" on the circuit board connects to or powers?
    I was going to contact Rick Jones of Motorrad Electrik and get his opinion. Anyone else with guru like BMW electric skills?
    thanks, chuck
    John D'oh
    Aug 2006
    15U - left side of top fuse/connectors (solid green wire) go to right switch (emergency stop) and to the ignition/headlight switch. I noted that the top 8amp fuse looks fine - is that true? The other side of the fuse connects to the coil which connects to the starter relay which is connected to the battery among other places. There is a factory wiring diagram for all 1977 /7 motorcycles that has a reliable circuit diagram for your RS. I have a PDF. I need to figure out how to get it to you...
    John D'oh
    John D'oh
    Aug 2006
    1977 R100RS factory wiring diagram pdf - Lets see if this works.
    Attached Files Attached Files
    John D'oh
    Aug 2011
    Orlando, Florida
    Thank you much, great diagram.
    Let me sort through this but it appears at first look that there is a correlation for the two shorts/failures.
    chuck
    Aug 2011
    Orlando, Florida
    Well I have found time to work on the RS and installed the refurbished starter from motorad elektrik. I also removed the headlight bulb holder/wires, which you recall was melted. Then I removed the right handlebar switch/wires (starter button, kill switch and turn signal blinkers). The wires that go to the kill switch, in the right handle bar switch assembly, are melted/toast. All of the other wires, on the switch look fine.
    Max BMW shows the headlight bulb holder/wires as available but shows the right handlebar switch as no longer available, I will call them to discuss. If the right handlebar switch is no longer available, any thoughts on how to install a separate kill switch somewhere on the right handle bar? Any thoughts/comments about eliminating the kill switch and use the key to start and kill the engine? Any sources for a used right handlebar switch? thank you for your help. chuck
    Check with Re-Psycle BMW to see if they have a good used handlebar switch. The price will be better and will likely look more like an original aged switch.
    https://re-psycle.com/
    Liaison 20774's Avatar
    Quote Originally Posted by mybmw View Post
    Years ago, when I didn't know what I was doing (likely still don't!), I shorted out the kill switch wiring on the right handlebar. I was mounting the gas tank and one of the connectors on the coil was bent out too far and contacted the inside of the tank. After tracing things down, I figured out where the smoke came from. I wanted to have the kill switch capability even though I rarely use it. I bought a latching switching at RatShack and basically followed the wiring diagram and ran two wires out to the switch and buried the switch within the wire bundle coming out of the right side of the bars. I've not even tried to use it and doubt I'd be able to really get to it quickly. But I think I still retain the kill switch capability. So, I'm sure it can be done. Sorry for the small less than clear picture.
    Attachment 71585
  1. 1977 R100RS Horn
    By mybmw in forum Airheads
    Last Post: 10-22-2015, 10:02 PM
  2. Lowering a 1977 r100rs
    By chippena.f in forum Airheads
    Last Post: 08-25-2013, 09:12 PM
  3. Replies: 7
    Last Post: 06-04-2013, 01:59 PM
  4. 1977 R100RS Fork Oil?
    By Darryl Cainey in forum Airheads
    Last Post: 05-28-2009, 02:56 AM
  5. 1977 R100RS Sidestand
    Last Post: 02-12-2006, 04:55 PM
