Results 1 to 5 of 5
Thread: 05 R1200RT -Using Factory TDC Tool To Set Valve Clearance
    Canberra,Australia
    Has anyone had experience in using the factory tool to locate TDC
    An Australian vendor sells an after-market version with a consistent diameter of 8.5mm, with no notched end for locating purposes
    But my Haynes manual shows a tool with a reduction of the tip down to 5 mm diameter, with a 5mm length
    This Haynes version appears to be very similar to the TDC tool for Oil head motors
    Any comments ?
    Bill
    Canberra
    Australia
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Such a tool is not needed to check/set valves.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Liaison 20774's Avatar
    Bill -
    I believe this bike falls in the Hexhead/Camhead area. There are a couple of DIY threads in the following area that mention valve clearance checks:
    https://forums.bmwmoa.org/forumdispl...Y-Tech-Library
    Maybe see if those DIY posts discuss the tool and/or any need for it.
    Jul 2007
    Sorry for my brief answer. A four year old took priority. The link Kurt provided has an excellent pictorial on setting the Hexhead valves, as well as several other maintenance procedures. My Haynes Manual for the Hexhead shows using marks on the cam chain sprocket to find TDC.
    Kevin Huddy
    CENTEX USA
    Have used the marks on cam sprockets on both Oilhead and Hexheads, the marks are harder to see on Hexheads, but they are there.
    Steve Henson-Mod Team and club tire changer
  1. R1200RT Wethead Valve Clearance at 24,000 miles
    By hefy_jefy in forum Wetheads
    Last Post: 09-05-2016, 11:11 PM
  2. 2013 R1200RT - valve clearance check? And changing trans oil?
    By NATHANMONK in forum Hexheads/Camheads
    Last Post: 01-24-2014, 04:46 AM
  3. 86 R80 valve clearance
    By roncooper in forum Airheads
    Last Post: 02-17-2012, 04:23 AM
  4. Valve Clearance
    By ROYBARNES in forum F-Twins
    Last Post: 09-10-2009, 01:30 PM
  5. Valve Clearance
    By sumran in forum Airheads
    Last Post: 02-27-2008, 02:08 AM
