After filling up with gas I was unable to start my bike with the clutch handle pulled in. After a few minutes of checking the clutch switch wire (not much can be done with this since it is enclised and connected under the tank) I put the bike in neutral and it started without issue.
Once I got home I checked the connector under the tank and all is good i.e. power at the connector from the starter circuit and continuity across the connector from the lever side. I was able to repeatedly start the bike in neutral so it is a clutch switch circuit issue I believe.
Any where to go next? Starter circuit locations?
Thanks,
Charlie
1992 R100R, 46k miles
