Results 1 to 10 of 10
Thread: R75/5 low bar dimensions
    The handlebars on my R75 are ugly and I would like to swap to low or euro bars. The ones that I am finding seem to be 25-27" in width. My high bars measure 30 wide. Is the 25-27 width normal for the low bars? Any recommended sources? I know I need 22mm bars.
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    You need not only the bars; but cables and possibly electricals....Anyway, Bench Mark Works has the advice, parts, and expertise that you want and need. Not connected to them except by their fantastic part supply and knowledge....Good luck.....
    http://benchmarkworks.com/onlinestore/partno.htm
    Liaison 20774's Avatar
    Registered User k12lts's Avatar
    Jan 2007
    Indiana
    Here is some info from Flanders that shows the difference between the Euro (/5) bars compared to the sidecar and 90S bars.
    http://www.sideroadcycles.com/Import...MaguraBMW.html
    2010 R1200RT, 2011 Ural Patrol
    2006 KLR 650, 1981 R100, 1975 R90S
    BMW MOA 37304
    bars
    With much deliberation, i have a set of super bike bars that are close to the euro dimensions. They are 7/8" and WILL work for the BMW perches. The best thing is i am not spending a ridiculous amount of money for 22mm bars.
    So you can use 7/8" bars? I wasn't aware you could. Since they're bigger in diameter, that means you'll have to be careful not to stretch the stock perches so much as to crack them...I don't think they're made of the stoutest material.
    My 35.5 cents worth
    I have changed out the bars on my rider /6 with the /2 US replacement bars offered by Bench Mark Works. I have an early /5 with the Euro bars (short "S" type) and when any of the cables get troublesome I will go with the /2 US replacement handle bars without a second thought. The low "Euro" bars look good but they are not a good fit for handling and ergonomics and the stock '70> bars just plain suck as far as I'm concerned.
    Installing the handlebar mounted controls will probably be an even bigger problem. Maybe not, but the one time I tried it the new bars went bye bye.
    Pismo Beach, CA
    I had the same experience that Paul had. My /5 perches would open up enough to fit on 7/8" bars unless I omitted the wedges (of course then there was nothing to stop rotation). New bars went back.
    7/8" grips, no problem.
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    Funny--I've always wondered what those wedges were for.
  1. Dimensions
    By sromaine in forum Straight 6 K1600 GT/GTL/B
    Last Post: 12-16-2013, 06:39 PM
  2. OEM battery dimensions
    By Phone Guy in forum Oilheads
    Last Post: 06-04-2011, 05:59 PM
  3. K75 C Bar Dimensions
    By MICHIGANMIKE in forum Flying Brick K-bikes
    Last Post: 09-21-2010, 06:02 PM
  4. Monolever RT dimensions
    By 73043 in forum Airheads
    Last Post: 03-28-2010, 02:37 PM
  5. K 100 LT Wheel dimensions
    By JohnHall in forum Flying Brick K-bikes
    Last Post: 12-29-2005, 08:16 PM
