Results 1 to 11 of 11
Thread: Oil Filter Damage
    Sep 2006
    Washington State
    Oil Filter Damage
    I know cold oil and high RPM's can collapse the filter. I thought it crunched the filter paper not bend metal.
    Liaison 20774's Avatar
    Looks pretty serious. Your bike and your filter? So I'm guessing you did start under cold situations and the RPMs got high? Have you been able to assess what if anything happened to the engine??
    Mansfield,MA
    Or- manufacturing defect you were really not supposed to see?
    Mod Squad
    2009 F800GS 1994 TW200
    Sep 2006
    Washington State
    78 R100/7, Had it from new. Just turned 100,000 miles . Runs great would take it anywhere . Aware of high oil pressure on a cold engine in cold weather (had a pressure gauge). Always take it easy till warmed up. I thought maybe a defect. Only use BMW parts.
    I have the same bike, same situation with miles. Can't say as I've looked under the paper filter much...I know I should though. I'm in a warm climate most of the time, so I don't think I've ever experienced that before.
    Sep 2006
    Washington State
    That's what I think. That is some heavy metal to bend with oil pressure.
    Mansfield,MA
    Never know what is inside until you "go deep". I just changed oil(s) on a Cummins M-11, 43 quarts. The oil filter holds around 2 quarts. It's a filter that I can't crush by normal means due to a "stem" that is about 8" long inside the filter.
    I think your fine.....kinda interesting though
    Mod Squad
    Nick Kennedy
    Nov 2011
    Telluride Colorado
    I'm too lazy too look but I thought a airhead motor had a oil pressure reducing valve, kinda like a old VW..
    A spring with a piston that that lets excess pressure past.
    Yes it does but if it's frozen closed...
    Rich Pelton Rich's Avatar
    Sep 2003
    Killdeer, ND
    I have a seriously hard time believing that engine oil pressure would do that. With the pressure that would take, I think other issues would crop up. Fast. I agree with the manufacturing defect.
    Snowbum suggests that the oil pressure can get quite high under cold conditions. He writes that the pressure relief valve opens around 75 psi. If that fails to open, then the higher pressure could collapse the element. If that happens and completely blocks the flow of oil, the main galleys in the engine would be starve for oil.
  1. PR4 Belt Damage?
    By dbrick in forum Motorrad
    Last Post: 05-30-2016, 07:30 PM
  2. Head Damage
    By 37071 in forum Airheads
    Last Post: 11-18-2010, 01:32 AM
  3. oil seal damage
    By cwilson in forum Oilheads
    Last Post: 09-18-2010, 03:31 AM
  4. water damage
    By paulfinney2 in forum Airheads
    Last Post: 06-29-2008, 03:04 AM
  5. Damage to finish
    By chfite in forum Gear
    Last Post: 09-04-2006, 09:27 PM
