Results 1 to 4 of 4
Thread: What to look for when buying a 1200 GS?
    I'm thinking about upgrading from my 2009 RT to a 2015 or later 1200 GS.
    1. What should I be looking for when looking at a used GS?
    2. Are there any known weaknesses in the years 2015, 2016, 2017 or 2018?
    3. What was changed or upgraded in each of those years?
    Thanks!
    Knight-Errant 1957mpd's Avatar
    Feb 2018
    Las Cruces,NM
    2017 brought a new transmission. Someone will correct me if I am wrong, but I think across the R1200 line-up. It shifts a little better than prior versions.
    "Soló el que ensaya lo absurdo es capaz de conquistar lo imposible." Miguel de Unamuno 1905
    Mark - Las Cruces, NM - '17 R1200 GSA
    Mar 2011
    socal
    I believe some changes made mid 17 they are called 17.5 models if i’am correct
    Buying used I would want to see service records, to ensure bike was at least serviced to Bmw specs
    Money well spent would be to have a bmw dealer inspect and give you a written report on bike, several friends did this on used bikes and saved themselves a lot of grief later on
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    Quote Originally Posted by javadave View Post
    Thanks!
    A known weakness is the fork recall that was for at least some of those years. Its easy to check that whether or not the work was done on any bike you look at by checking the vin number (as well as visually, although I can't describe what the changes are because I own an RT).
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
  1. More 1200 Gs on road than 1200 RTs
    By nelliott in forum Hexheads/Camheads
    Last Post: 05-27-2019, 01:24 PM
  2. Thinking of buying 1200 GT
    By Onebeemer in forum Wedge K-bikes
    Last Post: 09-25-2011, 02:13 AM
  3. Buying a used GS
    By devarts in forum Hexheads/Camheads
    Last Post: 02-08-2011, 08:22 PM
  4. Buying 1st BMW
    By xcell1600 in forum Hexheads/Camheads
    Last Post: 09-01-2009, 01:35 AM
  5. got s%#@ buying RT
    By ghostridery2k in forum Campfire
    Last Post: 12-27-2007, 07:37 PM
