Results 1 to 15 of 17
Thread: 2019 r1250 rt
    2019 r1250 rt
    I saw the announced BMW R 1250 RT (and GS) and I must admit I'm disappointed. I bought a new 2017 R 1200 RT in May this year and the only thing I could think of to improve the bike (I just returned from a 3,500 mile trip on the stock saddle) would have been LED headlights. I don't understand why BMW has neglected this feature for so long. Without going into details, I will be buying a new BMW RT in the near future and will probably opt for a 2018 because I'm sure there will be a significant savings and I was perfectly happy with the 2017 except for the lights.
    Registered User ballen262's Avatar
    May 2014
    N. Idaho
    Quote Originally Posted by mxsx337 View Post
    I installed two sets of led fog lights in the front, one set where the factory goes and a set on the forks using the CanSmart from Daneli and its the best riding bike at night now, and even if the bike did have led headlight I would still do extra lighting anyway.
    Registered User alegerlotz's Avatar
    Mar 2015
    Greater Los Angeles
    I hadn't heard anything about the headlight... that was one big area for improvement (going to LED).
    I wonder if they fixed the lousy bluetooth audio quality for satellite radio on the 2019+. My guess is No.
    2016 R1200RT
    2007 KTM 450 XC-W (10/17 - 5/18)
    2005 R1200RT (2/2015 - 12/2016)
    1985 Yamaha XJ 700 Maxim (7/1989 - 9/1991)
    Registered User marcopolo's Avatar
    Feb 2005
    Alexandria Virginia/Ottawa, Canada
    There is a rather extensive press package for both new bikes, GS and RT. Here's what is says about lighting:
    "For decades now, BMW Motorrad has been regarded as a frontrunner when it comes to safety in connection with motorcycling. One shining example in the truest sense of the word is the LED headlamp which is now offered as a standard feature of the R 1250 GS. In addition to this, the LED daytime riding light is available as an optional equipment item for the R 1250 GS and also the R 1250 RT, which has halogen headlamps. The LED headlamp of the R 1250 GS illuminates the road with a hitherto unrivalled clarity, thereby ensuring additional perception in traffic. The light unit consists of two LED units for low and high beam and, in connection with LED daytime riding light as an optional equipment item, four additional LED units for daytime riding light and side light."
    Mark
    2015 R 1200 GS Adventure
    Tucson, AZ, & Madison, WI
    2019 BMW R1250RT Announced by BMW NA
    https://www.bmwmotorcycles.com/en/mo...r/r1250rt.html
    Specs:
    http://bmwdean.com/2019-specs.htm
    The Spezial Blue Planet Metallic R1250RT is beautiful, but I may stick with my 2015 and 2017 RTs.
    Jeff Dean
    Tucson, Arizona, and Madison, Wisconsin
    Co-founder, 1972, of BMW MOA -- http://bmwdean.com/r1200rtw.htm
    2017 R1200RT, 2019 R1250RT, 1967 R60/2
    Quote Originally Posted by ballen262 View Post
    Can you attach a photo? I'm not sure exactly what you mean by "one set where the factory goes..." Did you put fog lights INSIDE the RT headlight assembly? Sorry for being "thick-headed."
    Registered User easy's Avatar
    Feb 2005
    Texas Hill Country
    Good Point.
    They could also put a little thought into making a transmission for the RT that shifts smoothly and silently from neutral to first gear - something that should have happened long ago.
    E.
    May 2014
    N. Idaho
    Sorry bro, Im saying stock fog lamps go on a bracket mounted to the front engine cover putting the fog lights just in front of the cylinder heads, second set is mounted to the front forks close to the center of wheel.
    The other brackets you could use to mount fog lights allows you to put fog lights up close to the turn signal lamps which I was not going to do, looked stupid to me.
    With all four fog lights installed my next install will be Touratech LED headlight that will replace my stock halogen, then Ill be set.
    Trust me if your in front of me with my high beams on along with my fog lights on it WILL blind ya.
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    Those shiny LED headlights on GSA's are $2K to replace out of warranty...
    Even though the H7 bulb may be old fashioned, it is availably at any gas station in the middle of nowhere although it is a PITA to get at....
    I added enough Clearwater lights on my RT to melt retinas (they are actually adjusted correctly) and blacktop.. YMMV
    MOA # 108516
    Current ride 2018 R1200 GSA Triple Black
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA, ‘17 R1200RT
    R1200RT Artiee's Avatar
    Jul 2008
    Northern Virginia
    For me, the timing couldn't be better. Earlier this year my wife agreed to the purchase of a new RT as soon as the current car payment is done. In the spring of 2020 I'll be rolling the car payment over to a new RT. I might be able to get a good discount on any 2019's still on the show room floor. I'll be replacing a 2005 RT.
    Experience IS NOT the best teacher! Someone else's experience is the best teacher.
    Ute's Chauffeur
    Sep 2006
    Central NY
    I would have liked LED lights (although my Sevina/Erica setup puts out huge light a significant portion of it is “wasted” lighting up trees and such as opposed to a light with properly shaped driving beams). The dash has a good amount of real estate that would have taken a large digital panel with Apple/Android connectivity. An option to eliminate the radio system and just have the latest version of bluetooth with the system allowing different data streams to 2 helmets so rider and pillion can listen to different sources. Turn the speaker spaces into lockable storage.
    For my needs and ability BMW does the mechanics fine, it’s the “other”stuff” they fall down on.
    Quote Originally Posted by cruisincruzan View Post
    Turn the (radio and) speaker spaces into lockable storage.
    +1!
    Jeff Dean
    Dec 2014
    Sacramento, CA
    Quote Originally Posted by bmwdean View Post
    +1!
    Agree, radio/speakers is a waste of space and weight. If I wanted to play music so everyone around could hear me, I would have bought a Harley!
    Dave
    2015 R1200rtw San Marino Blue
    2005 R1200rta Red - sold; 1999 R1100 Blue - sold; 1998 R1100S Yellow - gone
    1975 R90/6 - My first love, and still in the garage
    Registered User kioolt's Avatar
    Maryland
    The noise that Harleys make is not music to my ears.
    2004 R1150RT 186,800 miles , 1991 K100LT 128,700 miles, 1982 R100RT 106,900 miles
    Total 422,400 BMW miles
    AMA,BMWRA,BMWMOA
    The cheapest thing on a BMW is the nut that connects the handlebars to the seat.
    Registered User AKsuited's Avatar
    Jul 2009
    Southern Tier of New York
    My 2015 R1200GS came with LED headlights and I added the BMW auxiliary lights which are also LED's.
    My fleet: 2015 R1200GS, 2017 Toyota Prius Prime (plug-in hybrid)
  1. Tennessee in 2019
    By PGlaves in forum Rally Forum
    Last Post: 01-02-2019, 12:28 AM
  2. 2019 s1000rr
    By Lee in forum S1000 - The Hothead
    Last Post: 10-27-2018, 04:25 PM
  3. 2019 BMWMOA location?
    By 42831 in forum Rally Forum
    Last Post: 08-24-2018, 12:31 AM
  4. 2019 R1250rt?
    By T-foiler in forum Wetheads
    Last Post: 05-13-2018, 03:02 PM
  5. Replies: 39
    Last Post: 04-02-2018, 04:19 PM
