Results 1 to 15 of 15
Thread: 1988 K75 - Tech Help Requested
    Hi All,
    Apologies if this is somewhere in the myriad of posts, but here goes...
    Having some issues with the 1988 K75, ~53k miles...
    Initially the bike would run pretty good for the short rides I would do (less than an hour). Then went out on a longer ride and after a couple hours it started to sputter/hesitate/miss low rpm up to about 3500 rpm then it would run ok above 3500. Thought maybe bad gas, but...
    This weekend I went on a ride to Oshkosh and same thing, after about an hour of riding. Except this time it got worse. Sputter/hesitate/miss through all RPM. It very gradually would increase speed and once up to speed it would hold it, but still sputter/hesitate/miss, no good acceleration, occasional bursts of power for a second where it seems like it wants to go, then more sputter...
    Today it started the same thing after about only 5 mins of riding.
    Any ideas or questions to help troubleshoot?
    Thanks!
    K75 Newbie
    Mansfield,MA
    Welcome to the forum!
    I’m far from an expert on this bike. The next time it does this, somewhere quite, open the gas cap and see if you can hear any type of vacuum “whoosh”. Your description sounds like it’s starving for fuel.
    Good luck.
    Gary
    Mod Squad
    2009 F800GS 1994 TW200
    Oct 2009
    Torrance CA
    Have you ever replaced the fuel filter? Sounds like fuel starvation.
    I had a genuine BMW filter plug solid with varnish. Not a spec of dirt in it, but you could not even blow air through it.
    BTW, Autozone has a filter that is the exact same size and shape (all metal) for a fraction the cost of the BMW part. Sorry no PN, but take the stock filter with you, it is obvious which one it is.
    Scott
    2009 R1200R Roadster
    Dec 2008
    Belle Plaine, MN
    The previously mentioned options were my first thoughts also. (fuel starvation)
    As Gary suggested, if the tank vent is clogged there will be a vacuum in the tank that reduces the amount of fuel that is delivered. Presuming the tank on a K75 is similar to a K100, there should be two tubes that exit the bottom of the tank. One is a cap drain to redirect water from the cap. The other is the tank vent. You can attach a short hose to these to test airflow. The cap drain should pass air freely. The vent should allow some airflow until the tank is pressurized, then allow the air to exit once the air source is removed.
    The fuel filter, as Scott suggested is also a prime candidate for restricted fuel flow. It can be removed from the tank and tested after it has had time to drain and dry out inside. It should pass airflow with almost no resistance. Any resistance would suggest at least a partially clogged filter. If it hasn't been replaced in a while, it's probably easier to install a replacement while you're in the tank rather than wait to test and consider the need to replace it.
    Disclaimer: There are lots of more qualified experts here - I'm only relaying information that I've found and used in the past.
    Hope that helps.
    Monte
    85 K100RT
    Thanks for the suggestions Monte, Scott, and Gary. I'll let you know what is discovered as I check into the tank vents and filter.
    Be careful with aftermarket filters.
    They MUST be rated for high pressure (above 100 psi). Working pressure is 38psi, but if the regulator fails or you put a gauge straight to the pump while testing, you could see 100 psi. A lot of filters that look exactly the same dimensions are only rated for around 15 psi.
    Thanks for the heads-up!
    Replacing the filter is a good idea. I would also examine the spark plugs. If they seem bright white that confirms a lean running condition. If however they seem dark and show signs of wetness that would indicate a rich condition. If this is so, then suspect the engine temperature sensor. If the sensor is faulty and the ECU thinks a hot engine is still cold the bike will run rich and can get cranky (tech term ).
    Thanks, will recheck plugs too. I did replace with recommended plugs ~500mi ago.
    Hi All,
    Thanks for the suggestions. I replaced the fuel filter and checked the plugs. No improvement after replacing the fuel filter. Plugs 1 and 2 (front and center) are white tipped. Plug 3 (rear) looks normal with a tan/light brown tip.
    Any suggestions for next things to check would be welcome!
    Thanks again.
    Tim
    Feb 2009
    Mississauga, Ontario
    Try replacing the engine temperature sensor as Paul suggested. I had a similar problem and a new sensor corrected that.
    Walter
    Every decent man is ashamed of the government he lives under.
    H. L. Mencken
    Quote Originally Posted by WalterK75 View Post
    Thanks, will try that.
    Nov 2009
    Phila
    Millivolt signal trouble? 30 year old spade connectors that were not gold plated
    Old K bikes use millivolt signals to go through many spade and double pinch connectors: under seat computer K1, fuel injectors, sensors( rotation . . , ). These are not redundant meaning if one blade is corroded the millivolts can easily stop flowing and can start again in about 1/5th of second. If your "hesitation" is quick, quicker than you could flick the cut off to off and back on, you might need to have less corroded millivolt connections.
    The act of unplugging and plugging is supposed to wipe corrosion off, what do you know, if you buy a new sensor X, half of the connection is new and half of the connection just got wiped (shined up). I've advocated using an eyedropper bottle of Stabilant 22 (is NAPA contact enhancer CE 1 . $75). You wet a supplied Q tip, rub both sides of the spade( you may hear a little sizzle, it's airplane stuff) and wet the entrance to the mouth of the mating connector, plug it back in, maybe several times to wipe the spade. I carry it and have used it every few years on my 1985 K100RS with 198,000 miles, on the underseat K1 computer connector especially, I rarely replace sensors although water temp and throttle pos. sensors have been replaced.
    My bike has not been towed although twice my sons brought me a clutch cable (40 and 40 miles) that I keep over my workbench, a third time I rode it 10 mi home without a clutch cable. I've bump started it many times when the sprag clutch just whirred. I've used jumper cables with the"car" not running. I made a u turn one morning to rebuild the oil/water pump.
    Hope this line of thinking helps others keep the old K bikes rolling with fewer "QUIRKY" "make you nervous" shut offs and back on mostly for "NO REASON."
    177inthe70s
    Phila PA
    Sep 2018
    New York
    If you have a ohm meter you should be able to test your temp. sensor. It may save you from replacing a good unit or verify a bad one. You will however have to search for the table listing the resistances vs. various temps.
    Quote Originally Posted by tubeless View Post
    Tubeless,
    It's in the Tech Library at the top of the Flying Brick page.
    https://forums.bmwmoa.org/showthread...erature-sensor
  1. SHO-1 and Nav V Help Requested
    By texasslim in forum Straight 6 K1600 GT/GTL/B
    Last Post: 06-22-2016, 11:56 AM
  2. Bolt size requested. . .
    By rowemesp in forum Oilheads
    Last Post: 04-02-2007, 08:33 AM
  3. Recomendations requested
    By MOTORMAN in forum Oilheads
    Last Post: 06-20-2006, 12:05 AM
  4. Recomendations requested
    By MOTORMAN in forum Flying Brick K-bikes
    Last Post: 06-19-2006, 12:18 PM
  5. '78 R100S Motosport Help Requested
    By braddog in forum Airheads
    Last Post: 10-19-2005, 02:19 AM
