Results 1 to 11 of 11
Thread: 1972 BMW R75/5 - Rear Drive Shaft Boot Shavings?
    Registered User b25bsaboy's Avatar
    Aug 2010
    Calgary, AB. Canada
    Good morning to you all,
    Yesterday I cleaned up the rear swing arm area and removed the transmission drive shaft transition boot, turned it inside out and discovered the following fillings. Where would have this come from?
    Rick MacPherson
    Success is Not a Destination, But a Journey.
    Accredited Motorcycle Appraiser
    1968 BSA Starfire, 73 R75/5 SWB, 2008 Honda GL-1800 Lehman Trike
    Liaison 20774's Avatar
    Could they be broken washers? From the factory they would have used long bolts with washers. They could break and the bolts would loosen creating havoc. Replacement bolts are shorter with no washer.
    Aug 2018
    Fargo, ND
    Are the pieces steel or aluminum? Looks like aluminum to me.
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by poorub View Post
    Good Question! Will check.
    Rick MacPherson
    Nick Kennedy
    Nov 2011
    Telluride Colorado
    Wherever it came from it can't be good.
    Hope you find the source and its a easy fix.
    John D'oh
    Aug 2006
    Close to Fort Worth Texas
    Those are aluminum threads from one or more shaft housing fill/drain plug holes in the final drive...
    John D'oh
    Pismo Beach, CA
    If they ARE aluminum (looks like it), that's about the only thing I can think of too.
    Keensert time...
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
    #4869 DennisDarrow's Avatar
    Sugar Valley, Ga
    Definitely threads; but from where and how did they end up where they did...…….Is it making any shouldn't be making noises....Grinding???
    Registered User PAS's Avatar
    Jun 2011
    N.E. Ohio
    The rotation of the driveshaft pulls gear oil forward towards the gearbox.
    John D'oh
    Aug 2006
    Quote Originally Posted by PAS View Post
    - what PAS said. I would add that the oil moving towards the gear box washes through the bearings in the "U-joint" from centrifugal force carrying any odd debris with it of course - which is how the bits wound up in the boot.
    Check the fill drain plugs on the final drive. Specifically, the threaded holes one near the stamped numbers representing the gear ratio - and the one below it. You will either see threads or no threads. Possibly, a thread insert repair. Those are the fill and drain holes for the steel drive shaft housing. The actual final drive drain is on the housing bottom at 6:00 and the fill hole is at the rear of the housing at about 9:00. If you find nice clean original threads I'd bet the bits are from an earlier final drive unit. The plugs only need a few ft lbs of torque on new washers to stay put.
    John D'oh
    Aug 2010
    Calgary, AB. Canada
    Quote Originally Posted by b25bsaboy View Post
    Thank you to all that responded to my question.
    Found the culbert, as it appears when I drained all the oils, I didn’t pull or back out the top filler plug and it appears the PO was a little bit heavy fisted.
    Guess its HeliCoi or Time Sert time again
    Rick MacPherson
  1. Drive shaft boot filled with oil
    By arhd63 in forum Airheads
    Last Post: 03-13-2017, 05:47 PM
  2. Oil leak drive shaft boot
    Last Post: 01-20-2017, 08:28 PM
  3. leaky drive shaft boot
    By Gpr100rs in forum Airheads
    Last Post: 09-15-2012, 03:19 AM
  4. /5 Drive shaft boot
    By robertklee in forum Airheads
    Last Post: 04-07-2009, 02:28 AM
  5. Replies: 0
    Last Post: 05-18-2004, 11:20 AM
