Results 1 to 4 of 4
Thread: K Bike & Dirty Oil
    K Bike & Dirty Oil
    Both of my K-Bikes (2004 K1200RS & 2008 K1200LT) have developed an interesting habit of late. I don't seem to be able to drain all of the old oil out of the bike during oil changes. When I add fresh oil it turns dark within a minute after starting the bike to check for leaks. Does anyone have any tips to help out?
    Drain it HOT. Drain it initially through the oil filter cover and then through the drain plug after the majority is out.
    If that doesn't help, pull the bottom of the oil pan off and clean the sludge that is in the bottom. Reseal and install the pan and you should be good to go.
    Belton Tx
    My 91 k75rt has done the same since I bought it used a hundred thousand miles ago. Other vehicles that I own the oil stays cleaner looking at the same change interval.
    Ron
    91 K75RT ABS
    May 2008
    Western Massachusetts
    Quote Originally Posted by 119980 View Post
    Do you change the filter (and open the filter cover) at every oil change?
  1. Dirty float bowl
    By harmonyhenry in forum Airheads
    Last Post: 08-13-2015, 01:13 PM
  2. I need the down and dirty
    By ultracyclist in forum Thumpers - F & G bikes
    Last Post: 09-30-2013, 05:07 PM
  3. Dirty,Dirty,Dirty
    By 140008 in forum Airheads
    Last Post: 11-02-2011, 09:56 PM
  4. Best Dirty Bike Wash?
    By kantuckid in forum Gear
    Last Post: 03-11-2009, 07:05 PM
  5. Dirty transmission oil
    By OfficerImpersonator in forum Oilheads
    Last Post: 02-07-2008, 12:34 AM
