BMW Motorrad ADVANTEC Pro oil SAE 15W-50
You've not said which you are looking for, but my recollection is that most F-series bikes call for 15w50 Semi-Synthetic.
If you want to run a 15w40 Rotella, I would suggest their T6 as it is fully synthetic and therefore should provide as good or better protection as the original spec.
The differences between the Rotella offerings you listed are:
T4-dino (regular mineral oil)
T5 synthetic blend
T6 full synthetic
Not sure about T4 and T5 but my Rotella T6 is JASO MA2 certified, which is what you want for an F-series.
Yes. Sorry, I wasn't very specific there.Semi- synthetic is equal to synthetic blend, yes? So that means T5.
JASO JASO Oil Specifications
2T specifications
Japeneese motorcycle manufacturers found the limits demanded by the API TC specifications too loose. Oils meeting the API TC standard still produced excessive smoke and could not prevent exhaust blocking. Therefore the Japanese Engine Oil Standards Implementation Panel (JASO) introduced the following specifications:
JASO FA
Original spec established regulating lubricity, detergency, initial torque, exhaust smoke and exhaust system blocking.
JASO FB
Increased lubricity, detergency, exhaust smoke and exhaust system blocking requirements over FA.
JASO FC
Lubricity and initial torque requirements same as FB, however far higher detergency, exhaust smoke and exhaust system blocking requirements over FB.
JASO FD
Same as FC with far higher detergency requirement.
Find out more about JASO's 2T specifications from their website.
4T specifications
Modern passenger car engine oils contain more and more friction modifiers. While this is the good thing for those segments (reduces wear and fuel consumption) it's bad for the motorcycles. At least for those motorcycles which use engine oil to lubricate their transmission and wet clutch. JASO introduced the MA and MB specification to distinguish between friction modified and non friction modified engine oils. Most four-stroke motorcycles with wet clutches need a JASO MA oil.
JASO MA
Japanese standard for special oil which can be used in 4-stroke motorcycle engine with one oil system for engine, gearbox and wet clutch system. Fluid is non-friction modified.
JASO MB
MB grade oils are classified as the lowest friction oils among motorcycle four-cycle oils. Not to be used where a JASO MA grade oil is required.
Find out more about theJASO MA and JASO MB specs.
Guilty!I thought oil threads weren't supposed to start until winter. Is this a sign of a harsh winter like thicker corn husks or woodpeckers sharing a tree?
