Pulled the tank and cleaned all the wire connections between the coils and still getting a nice spark to the left and nothing to the right. switched plug leads and spark followed to the right side and nothing to the left. So what is the best test for coil function although I can not imagine the coil is bad as the bike ran fine before the Alpha system install. I will check the plug in sections for the new ignition system although they seemed to attach fine when installed. Electrical system diagnosis is not my strongest talent so any step by step would be greatly appreciated as this is really frustrating. the carbs where cleaned well and working fine before all the other work was started.
Looks like if you measure from cap to cap you'll get the requisite 22K ohms...I get that by adding up all of the individual ohms, leaving out the primary resistance. Doesn't mean the coils aren't breaking down in operation. Unfortunately, the only sure way to test this is to substitute known good parts...few people have coils just sitting around.
