Results 1 to 5 of 5
Thread: Kickstand safety switch
    Trouble shooting 2002 1150 RT. If I unplug the switch, will that bypass it, or do I need to connect the wires to bypass it?
    Liaison 20774's Avatar
    Welcome to the forum! Just noticed that there's at least one thread in the Similar Threads pane at the bottom of the screen that addresses this. Check 'em out!! Hope that helps.
    That is a normally "open" switch, closed when the brake is activated. Unplugging it leaves it open. You need to "loop" the wires to bypass the switch.
    On my 94 R1100RS I find it periodically useful to take some WD40 and squirt around the sidestand switch. I then exercise the sidestand switch (by moving the sidestand up and down several times). This usually ensures that bug guts and other road spooge gets cleaned from the switch and the WD40 helps remove moisture and precludes excessive corrosion in the switch.
    If the sidestand switch function is bypassed through the use of a jumper, take care to ensure that the sidestand is up before riding the bike.
    Mansfield,MA
    Quote Originally Posted by robsryder View Post
    on my 94 r1100rs i find it periodically useful to take some wd40 and squirt around the sidestand switch. I then exercise the sidestand switch (by moving the sidestand up and down several times). This usually ensures that bug guts and other road spooge gets cleaned from the switch and the wd40 helps remove moisture and precludes excessive corrosion in the switch.
    +1
    om
    Mod Squad
    2009 F800GS 1994 TW200
  1. R1200CLC Kickstand switch
    By miairhead in forum Oilheads
    Last Post: 09-15-2012, 10:55 PM
  2. Kickstand no start switch
    By xp8103 in forum Oilheads
    Last Post: 10-04-2009, 02:54 AM
  3. kickstand switch
    By gharrell in forum Hexheads/Camheads
    Last Post: 10-27-2008, 09:49 PM
  4. Kickstand switch on the RS
    By gnavecky in forum Oilheads
    Last Post: 12-13-2006, 05:24 AM
  5. Disable kickstand kill switch
    By birglte in forum Oilheads
    Last Post: 08-17-2006, 06:30 PM
