Results 1 to 5 of 5
Thread: Wiring Diagram for Trunk of 2019 K16100 GT
    Mehrten
    Nov 2004
    Arizona, USA
    I would like to know the color codes of the wires leading to the trunk that is equipped with a trunk light, high brake light and central locking.
    I have identified the brown and the gray-black-yellow as the brake light.
    There are two other pairs (?) that I don't know.
    Appreciate the help.
    Aug 2018
    Fargo, ND
    One pair may be for a heated passenger back rest. Seems to me the top case I put on my RT has it. You can easily remove the back rest, about 6 screws from the inside of the top case lid, and there will be a wire that is just laying under the pad.
    Mar 2018
    Ft, Wayne, IN
    The other 2 are for the dome light in the case. My backrest is off of mine right now. I'll post the colors for the heated back connector tonight.
    Sent from my SM-G965U using Tapatalk
    Mar 2018
    Ft, Wayne, IN
    White/Green strip & Brown is backrest heater. This is on my '18.
    Mehrten
    Nov 2004
    Arizona, USA
    Thanks for the info Guys.
    I took the top case cover off to determine which wire or wire set is for the brake light and the inner trunk light.
    These are the two connections I need to attach a Signal Dynamic license plate frame that has two rows of leds.
    Note that on the Bike Side of the harness there are five wires; on the Bag Side of the harness there are six wires.
    The difference must be for the various models of the K1600 that have more trunk connections - heat, volume control, etc..
    Here is what I found:
    Bike Side of Harness - Bag Side of Harness
    Brown-White to Brown White
    Purple-White to Purple-White
    Red-Green to Red-Brown
    Small Brown to Grey-Black-Yellow
    Large Brown to Small Brown
    (No pin) to Green-White
    The brake light comes off the Grey-Black-Yellow on the bag side of the harness and the Small Brown on the bag side of the harness; or the Small Brown and the Large Brown on the bike side of the harness.
    The trunk light comes off the Red-Brown on the bag side of the harness and the Small Brown on the bag side of the harness; or the Red-Green and the Large Brown on the bike side of the harness.
    One of the other wires (?) operates the Central Locking for the trunk.
    The other(s) must be for GTL or B model options or accessories.
    I won't be able to test the Signal Dynamics frame until our seat comes back from Russel Daylong, about the first week in April.
    Again, thanks for the info.
  1. Wiring Diagram
    By mordom@me.com in forum Scooters
    Last Post: 07-21-2015, 09:06 PM
  2. Wiring diagram
    By LCampbell in forum Airheads
    Last Post: 03-20-2013, 03:37 PM
  3. Wiring Diagram?
    By skesinger in forum Flying Brick K-bikes
    Last Post: 01-11-2013, 09:49 PM
  4. Wiring diagram
    By rvbeemer in forum Airheads
    Last Post: 12-17-2007, 08:37 PM
  5. Wiring diagram
    By RandyB in forum Airheads
    Last Post: 01-22-2007, 03:31 PM
