Results 1 to 4 of 4
Thread: 1987 K75C 48k Caribic Blue Brake Housing Assembly Right question
    PeteG
    Dec 2009
    Woodacre, California
    Smile 1987 K75C 48k Caribic Blue Brake Housing Assembly Right question
    Hello,
    I'm in the process of replacing the cylinder with piston (master cylinder). The housing is pitted (pic attached). Can it be cleaned and salvaged? Looks like that silver washer shown needs to be removed and replaced. I'm thinking it isn't critical as it just functions as a housing for the plunger, but I certainly am no expert.
    If replacement is needed can a mid-level-skill wrencher replace the housing only? Housing (10) 32 72 1 451 734 $73.26
    Thanks for your help in advance. I shall now try and post an icon.
    Pete
    Jul 2004
    Charlottesville, VA
    If you don't mind the flaking paint, the housing is perfectly fine if you just clean it up. Didn't the new master cylinder come with a new washer and rubber seal?
    Anton Largiader 72724
    Tech articles - YouTube
    PeteG
    Dec 2009
    Thanks for the help Anton. My ride is a 65 mile per day commuter vehicle. Flaking paint does not bother me. You are correct, the new MC did come with a new washer and rubber seal. I did find the old rubber seal when I removed the washer (after my post). Surprisingly the old rubber seal looked to be in good shape after almost 30 years. It will be replaced in spite of its excellent service.
    I appreciate the feedback.
    Ride safe!
    PeteG
    Dec 2009
    Smile
    Update: The replacement went perfectly. It took me much longer than anticipated to install the new master cylinder. I didn't want to force it into position by using bolt draw down. So with practice using the old unit and additional clean up thanks to my Dremel extension tool I was able to get the new mc almost flush (1/16 in.).
    There is one protruding part of the mc that fits into the housing that looks somewhat like a woodruff bit (pic shown). I was puzzled that there didn't seem to be a female counterpart recess, that could be felt, in the interior housing wall. Did I miss something?
    Anyway, thanks for getting me on my way into this project Anton!
    Pete
  1. '86 K75C headlight assembly
    By jad01 in forum Flying Brick K-bikes
    Last Post: 11-25-2017, 06:24 PM
  2. 1987 K75C 34.6K Oldest Karibic Bleu Brake Rotor Nut question
    By pjar in forum Flying Brick K-bikes
    Last Post: 04-04-2017, 06:33 PM
  3. 1987 K75C 19K Front brake rotor replacement question
    Last Post: 11-15-2015, 02:14 AM
  4. 1987 K75C 12.4k BLUE (the slow color)
    Last Post: 06-28-2015, 04:20 AM
  5. 1987 K75c
    By pakratk75 in forum Flying Brick K-bikes
    Last Post: 06-09-2007, 07:28 PM
