I appear to have a fault in my handle bar switch for the turn signals. Left position works fine, the turn signal flashes as it should. Right position is intermittent. The signal will come on, flash a couple times, then quit, going dark. Can this switch be disassembled to clean the contacts? The machine is a '67 model with the rotary switch with push button in the center.
