Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Disassembly of a lock cylinder when re keying
  1. #16
    Pepperfool GSAddict's Avatar
    Feb 2008
    Sechelt, British Columbia
    Quote Originally Posted by bmwroadsterca View Post
    What is the advantage of filling the tumblers? Isn't it simpler to just leave them out?
    Sent from my SM-G950W using Tapatalk
    Filing them makes them the size they need to be. Then you get the benefit of the security. No tumbler= no security
    Further to that the heel of the tumbler locks the barrel in the off position.
    Ufda happens..........
  2. #17
    Lanark County near Ottawa ON
    How does a tumbler that has been filed down give you any security?
  3. #18
    Feb 2008
    If the wrong key is inserted it won't sit flush.
  4. #19
    Well didn't filing it down when the wrong key is inserted make it flush?
  5. #20
    Feb 2008
    There are many more wrong keys than the one that was matched/filed.
  6. #21
    But only three positions for each tumbler !
  7. #22
    Feb 2008
    Filing a #3 will give you a #2 or further a #1
  8. #23
    Isn't it the case that a tumbler has one correct position and two incorrect ones and filing negates at least one incorrect position?
    Sent from my SM-T530NU using Tapatalk
  9. #24
    Feb 2008
    But you still have better security than no tumbler at all.
  1. 28L Top Case Disassembly Help - To Remove Lock Cylinder
    By ItsPhilD in forum Hexheads/Camheads
    Last Post: 08-23-2019, 10:24 PM
  2. Help, how do I replace the lock barrel cylinder followers?
    By mosrrt in forum Hexheads/Camheads
    Last Post: 08-21-2014, 05:13 PM
  3. Replies: 14
    Last Post: 06-28-2013, 10:31 AM
  4. Replies: 4
    Last Post: 10-02-2009, 11:52 AM
  5. CLC cylinder lock replacment on side case
    By nplenzick in forum Oilheads
    Last Post: 12-12-2003, 11:35 AM
