Results 1 to 15 of 24
Thread: Disassembly of a lock cylinder when re keying
    May 2016
    St Lazare, Quebec, Canada
    1999 RT. I need to re key a top box lock cylinder to match my bike. I have a pretty good grasp on how to do this but I have a couple of questions:
    Is Any force required to disassemble the removed lock cylinder tumblers? or do they and the springs fall out easily after key has been extracted? Special tool required?
    Will there be enough 1s, 2s and 3s from the existing lock cylinder to re key the lock or Is a kit of tumblers advised in case of shortage?
    Thanks, Flhfxd
    Pepperfool GSAddict's Avatar
    Sechelt, British Columbia
    No force required. Tumblers and springs easily come out when the key is removed - disassemble on a white towel.
    Depends how similar the key change is as to the numbers
    Ufda happens..........
    Gerard jagarra's Avatar
    Aug 2016
    Reno, NV
    Here is a link to a you tube video showing a top box from a K1600 model being done. He shows you how to count the different positions, so depending on the keys you have and the difference you may have enough to do the change. He indicated kits were available from dealer.
    https://www.youtube.com/watch?v=mygeTPWUhqY
    1994 R1100RS-(5/93)-,1974 R90/6 built 9/73,--1964 Triumph T100--1986 Honda XL600R
    Florida & Massachusetts
    Maxbmw didnt have them the last couple times I looked. Is there anyone else who has the rekey kits in stock?
    May 2016
    The only kits I can find on web contain the barrel as well as a dozen tumblers and springs at $50.
    Can we get just a kit of tumblers at a better price?
    Feb 2009
    Mississauga, Ontario
    Does Bob's BMW have what you need?
    Walter
    "Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
    Lanark County near Ottawa ON
    Most people don't bother with the kit. Do some Googling and learn how to arrange the existing tumblers to work. You may end up with a tumbler or two left over if the numbers don't work out but so what. By the way the video is totally wrong about their being only 24 combinations. There are many more than that.
    Sent from my SM-T530NU using Tapatalk
    May 2016
    Quote Originally Posted by bmwroadsterca View Post
    I was thinking that very thing. Use what I can and leave a slot or two empty as necessary. Yes. Use the factorial math to get the potential combos. Hundreds for sure
    Aug 2016
    Reno, NV
    Quote Originally Posted by flhfxd View Post
    A&S has them for less, $37.00, free ship.https://www.ascycles.com/bmw/1998/R1...tml#PartsTable
    Yes, but, how many did BMW use.
    5 for the ignition lock
    4 on the cases
    You can also use what you have, get as close as possible, and then take down any high spots that remain with the key inserted, and file them down. It works.
    May 2016
    Quote Originally Posted by roger 04 rt View Post
    . Will do it this way. Presently on the road at work. Looking forward to this as soon as I get home.
    Thx all for the tips. Flhfxd
    I remove the tumblers when I file them so that no bits get into the lock.
    What is the advantage of filling the tumblers? Isn't it simpler to just leave them out?
    Sent from my SM-G950W using Tapatalk
  1. 28L Top Case Disassembly Help - To Remove Lock Cylinder
    By ItsPhilD in forum Hexheads/Camheads
    Last Post: 08-23-2019, 10:24 PM
  2. Help, how do I replace the lock barrel cylinder followers?
    By mosrrt in forum Hexheads/Camheads
    Last Post: 08-21-2014, 05:13 PM
  3. Replies: 14
    Last Post: 06-28-2013, 10:31 AM
  4. Replies: 4
    Last Post: 10-02-2009, 11:52 AM
  5. CLC cylinder lock replacment on side case
    By nplenzick in forum Oilheads
    Last Post: 12-12-2003, 11:35 AM
