Results 1 to 5 of 5
Thread: Jiffy Tite Quick Connect : R1100GS 96
    Registered User GotFog's Avatar
    Jan 2015
    Defiance, MO
    A while back I installed some quick connects on my 1100GS. Stainless Steel models from Beemer Boneyard, these greatly facilitate fuel tank removal.They have worked well, but with the vulnerable exposed O-rings, I've grown paranoid. Current MOA has article on using Jiffy Tite robust connects as fool proof replacements, but am unsure as to correct series and size.
    Looking for input on correct sizing for fuel line.
    2000 versus 3000 series?
    It seems the AN 6 size is closest, but if someone has some idea what really works it would be helpful.
    Thanks.
    Jan 2005
    Roanoke, VA
    Quote Originally Posted by GotFog View Post
    Thanks.
    Why not just carry a couple of extra o rings?
    Jan 2015
    Defiance, MO
    Quote Originally Posted by virginiapi View Post
    Why should I settle for second best?
    Aug 2010
    North Ridgeville OH
    I haven't put them on a BMW, but I've used them in another application and am quite happy with them so far. I'm using them in a hot (oil vapor and crank case gasses) environment with a fair amount of vibration (direct mounted to the engine) which was combining to destroying the shut off valves in the CPC fittings. The only issue I've seen thus far with Jiffy Tite fittings is the locking balls wearing into the aluminum, but it hasn't caused a functional issue yet. RPW has the answer for your sizing questions:
    https://www.racerpartswholesale.com/...ne_Disconnects
    Jan 2015
    Defiance, MO
    Quote Originally Posted by rxcrider View Post
    Thanks for the response and the information you shared. I did in fact place an order with them and I'm waiting for the parts; not all of them are in stock but eagerly await, to do the modification.
  1. Valve cover stud: loc tite?
    By kwb210 in forum Airheads
    Last Post: 02-14-2011, 09:44 PM
  2. Gas Tank Quick -connect
    By SHEEPDOG in forum Regional West
    Last Post: 03-21-2009, 05:17 PM
  3. Loc-tite Dyna 3 Ignition pick-ups?
    By 20975 in forum Airheads
    Last Post: 04-08-2008, 01:15 AM
  4. OK where does this connect to???
    By RJM2096 in forum Oilheads
    Last Post: 03-07-2008, 10:33 PM
  5. Where to Connect
    By PAULBACH in forum Gear
    Last Post: 04-28-2007, 10:50 PM
