Results 1 to 8 of 8
Thread: Mystery tube
    Mystery tube
    Howdy,
    I have an 06 RT. Recently I noticed a tube hanging lose just below the tank glove box. After checking, I could find no trace of where it may have been attached.
    There were no indicater lights blinking.
    I thought that it could be an auxiliary tube for an antenna, but can't be certain.
    Would anyone know what this tube is, and where it belongs?
    G.
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Big Sky Country
    Quote Originally Posted by garydolgoff View Post
    Howdy,
    G.
    The word “tube” is confusing to me. Is it a rubber hose? Can you post a picture? My first thought is it is a rubber hose that has come lose from the charcoal canister.
    Kevin Huddy
    Hi, and thanks for answering.
    I don't have a photo of the tube, but that's the best description of the item. It's about a quarter of an inch thick with a very narrow opening (a female end)
    I wasn't aware of a charcoal canister on the bike.
    Nov 2011
    Central Ohio
    There is a charcoal canister on the right front, near the cruise control motor.
    There is a rubber tank breather hose from near the fuel filler to the canister. Actually I'm remembering it as two pieces, with a simple plastic tube to connect them in the glove box area. It separates when removing the tank for a brake flush.
    Ah, my memory still works (a little)! Look for the other part of the hose (2) with the connector (3).
    Larry
    2006 R1200RT
    Jul 2007
    Big Sky Country
    The charcoal canister is part of the emissions control system. It catches fuel fumes and overflow, hence the hoses, or tubes, coming from the fuel tank that lkraus described. Find the charcoal canister and see if you can see a connection point for the errant hose, or if the hose is connected to the canister and has come lose from the fuel tank end. I cannot recall how much of the canister you can see without removing some fairing bits.
    Kevin Huddy
    Quote Originally Posted by lkraus View Post
    Got it!!!!!
    Thank you all!
    Next question could be on stock market tips......or not
    Thanks again
    Jul 2007
    Big Sky Country
    Got it!!!!!
    Thank you all!
    Thanks again
    Buy low.... sell high.
    Kevin Huddy
    Sep 2009
    Chestnut Hill, MA
    FWIW the charcoal canister and associated hoses are part of the US-mandated emissions system. US bikes have that plumbing, and the rest of the world does not. RT owners have been known to perform a "canisterectomy" which eliminates the canister and re-routs some of the fuel lines. One of those dumps raw gas into the RH cylinder when some piece of the system overflows in the original configuration.
    Problems with the system usually result from over-filling the fuel tank. The overflow frequently gets routed to the canister and drivability issues sometimes result.
    John Gamel - BMW MOA Consumer Liaison
    2015 Ebony Metallic R1200RT
    “So often times it happens that we live our lives in chains
    And we never even know we have the key”
  1. Inner tube installation
    By joe garski in forum Motorrad
    Last Post: 05-28-2018, 09:43 PM
  2. Down tube painting
    By Motodan in forum Motorrad
    Last Post: 02-17-2018, 08:52 PM
  3. Mystery Drain Tube. . .
    By Walking Eagle in forum Oilheads
    Last Post: 10-01-2011, 12:35 PM
  4. Tube Sealant In A Can
    By AnnapolisAirhead in forum Airheads
    Last Post: 06-04-2008, 09:57 PM
  5. Oil Vent Tube
    By Slablog in forum Oilheads
    Last Post: 05-20-2008, 08:44 PM
