Results 1 to 4 of 4
Thread: Brake light wire code for ‘16 R1200RS
    Palouse rider
    Jun 2015
    Richland,WA, Eastern Washington
    I’m going to be installing the Weiser led brake lights on my ‘16 R1200RS. I’m wondering if anyone out there knows which wire in the back of the bike is for the brake light. These lights will enable the turn signals to also function as brake lights but I have to tap into the brake light wire to make these work. Just need to know the color code.
    Mar 2010
    Wills Point, TX
    Quote Originally Posted by steen1 View Post
    The following is for a wethead RT but I would assume it would be the same on an RS- it would be easy to check
    Blue/Black: Right turn signal
    Blue/Red:Left turn signal
    Grey/Red: Tail light
    Grey Black with Yellow dot: Brake
    Brown: Ground
    Jay
    Palouse rider
    Jun 2015
    Thanks Strataj, I’ll check it out. They should be the same, but with BMW, you never know!
    Mansfield,MA
    I find this wiring gets tricky- values seen......values expected. Any kit that is supposed to be (made for) on the bike should have all the installation instructions with it.
    Just what I like to see.
    Mod Squad
    2009 F800GS 1994 TW200
  1. wire up top box brake light on 2015 R1200RT
    By airride in forum Wetheads
    Last Post: 06-27-2016, 06:45 PM
  2. F700GS brake light wire colors
    By bmw700gs in forum F-Twins
    Last Post: 07-10-2015, 03:14 PM
  3. How to wire GSA Aux. light switch to aftermarket lights?
    By 110026 in forum Hexheads/Camheads
    Last Post: 01-06-2015, 07:15 AM
  4. PIAA Light Install Wire Set Up?
    By VTRider500 in forum Flying Brick K-bikes
    Last Post: 08-28-2007, 04:01 PM
  5. Replies: 4
    Last Post: 12-17-2004, 04:04 PM
