Results 1 to 9 of 9
Thread: K1600 GT with Aux Lights - Install another set branching off existing wiring?
    Here's one for all you electrically minded folks out there.
    My K1600GT has the factory fog lights installed. I am trying to figure out if I can branch off the existing lights wiring and install two more Denali DR1 lights (using the mirror mounts) and just run the necessary wires to them and have them function using the fog light switch on the handlebar. The total draw for both lights would be 1.5 Amps (0.75 Amps each).
    I do not know if the fog lights share a circuit with the GPS, or BMW socket, for instance, or if they are on a dedicated fuse.
    Anyone any the wiser?
    Andrew
    MOA # 210167
    Mars Red RT Triple Black S1000XR Bonneville Black Scrambler (carb)
    IBA# 5819 61996's Avatar
    Mar 2014
    Apple Valley, MN
    I don't think the CANbus system will like that.
    You might be better off with a PDM-60 or you can run the old fashioned relay/switch circuit direct to the battery.
    Good luck.
    Joe
    “Fate whispers to the warrior, 'You cannot withstand the storm.'
    The warrior whispers back, 'I am the storm.'
    more lights
    Quote Originally Posted by 61996 View Post
    Good luck.
    Joe
    Do you think with a PDM you could still tap into the fog light switch to switch all the auxillary lights?
    Mar 2014
    Apple Valley, MN
    Quote Originally Posted by FELAW View Post
    What you suggest would require cutting the harness...something I'm not a fan of.
    But in answer to your question: theoretically yes. The PDM would have to go in series with the switch. The switch would trigger the PDM which would turn on the lights.
    But again, I think the CANbus circuit might trigger a fault code.
    Joe
    To add context.
    I already have a Denali Sound Bomb installed, replacing the OE horn utilising a relay and wired from the battery. I was hoping to install extra lights without needing to add extra hardware, which I do not think is possible given the CANBus. I'm not very familiar with how they work, but I have read elsewher that the controller will sense the extra current draw and send an error message, probably shutting off the circuit which obviously defeats the purpose of the exercise.
    I'm pretty sure I'm going to do it right and order a Denali CAN-Smart that has all the necessary wiring and connections out of the box, and damn the extra cost.
    Andrew
    MOA # 210167
    Mar 2014
    Apple Valley, MN
    Quote Originally Posted by desmoderek View Post
    To add context.
    You should look into the PDM-60.
    The PDM is independent of the CAN Bus circuits.
    I use it to control 5 add-on's.
    Programmable and mounts under the seat.
    Neat and compact. Cleans up any extra wiring.
    Good luck.
    Joe
    Good luck.
    Joe
    Ordinarily I'd agree. I've used the Fuzeblock on Triumphs before and like the way it keeps it all neat.
    My goal this time is to integrate the control of the lights through the Wunderwheel and BMW switches. (You can change the brightness of the aux lights via Wunderwheel, or toggle them on/off using the turn signal cancel button).
    Thanks!
    Andrew
    MOA # 210167
    Thanks!
    Instead of going with the PDM60, i would recommend going with the HexEZcan product which integrate into the BMW CanBus and allows the use of the wonderwheel for operation while still using power directly from the battery, this is one hell of a powerful tiny box that solves a big problem.
    https://www.hexezcan.com/
    Good Luck!
    Registered User jonnybow's Avatar
    Apr 2019
    Delaware
    The EZCan is the right answer. Tapping into your aux lights wont work, it'll trip the circuit and shut them both down. using the Hex EZCan, you'll control the lights using your wonder wheel and set the intensity for day and night use with the computer. I have my lights at 10% during the day and night and they go to 100% when I hit the high beam and flash when I use the horn. You can also set them up to turn off when the turn signal is depressed so oncoming traffic can see the turn signals. Well worth the price of admission.
    Jon
    K1600GT & R1200GSA
    BMW MOA #220293
  1. How to install driving lights
    By Wethead in forum Wetheads
    Last Post: 06-02-2016, 07:20 PM
  2. Wiring LED Lights
    By brittrunyon in forum Airheads
    Last Post: 10-03-2013, 10:32 PM
  3. Replies: 4
    Last Post: 01-01-2013, 08:26 AM
  4. Replies: 3
    Last Post: 09-11-2012, 09:57 PM
  5. Install Hella FF50 lights on my R1100RT
    By mfifer in forum Oilheads
    Last Post: 12-27-2008, 11:26 PM
