I am working on a '67 R60/2. I have no manual and have some questions. There are rotary switches on each end of the handle bars. I am guessing that the one on the RH side is for the turn signals? And the center push button is for the horn? What is the LH side switch for? I put a new 6v battery in today and I have a red light. I assume this is the generator light? Finally, what are the switch functions of the ignition switch? I found that with the "key" pulled part way out and the battery wired in, the red light is on and goes out when the key is pulled out.
