The latch on my "94" K1100LT side case broke and I have the replacement latch. How do you remove and replace the lock? Tried a search with no luck.
If you're referring to changing the key/tumbler portion of the latch, take a look at this. The process takes longer to explain than to do:
http://www.ibmwr.org/ktech/topcasekey.shtml
Gary Phillips - #6322
Wildland Firefighter, Retired, Riggins, ID
Heartland Moto Locos BMW Riders
'77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
1der,
I added "Integral Cases" to your title to be more specific.
"A picture is worth a thousand words" so here are four thousand words plus a few:
Here is your lock cylinder with the retaining tab protruding. This is what you must push back flush with the cylinder to remove the lock cylinder.
This is the latch in the open position.
This is where the retaining tab ends up with the cylinder inserted.
This is with the cylinder inserted showing the retaining tab in place. Push the tab in, pull on the key to remove cylinder. Some rotation helps.
To install cylinder, with key in the cylinder, push into the latch rotating COUNTERCLOCKWISE until it is seated and stops rotating.
I was able to remove the lock assembly by pushing in the end detent spring on the end of lock. But now I'm unable to reinsert the lock assembly due to the spring not letting it in all the way. And to top it off my computer has a bug and unable to do much on it. Computer going into the shop Monday. Thanks for the help.
PS it's the R side case latch on the K1100LT
Nice pictures Lee
"You can do good or you can do well. Sooner or later they make you choose". MI5
Moderator Team.
2009 F800GS 1994 TW200
The latch hole has four slots. Start the lock cylinder with the locking tab in the slot that is at 3 o'clock. Push all the way in then rotate counterclockwise until it stops.
Trip computer? FI computer? What's it doing/not doing?
(I reread your post. If your talking home computer, we can't help you here. We all can barely post, email, and use ebay).
98lee,
Thanks...... Yes, pictures worth 4 thousands words. With the help of pictures AND a liberal amount of grease, along with a COUNTERclockwise rotation, lock cylinder popped into place. I'm good to go.
10-4 on (home) computer knowledge. In my case, lack of.
Here is the BMW Service Bulletin on removing and rekeying Intergral case locks. The rekeying process is the same for gas cap and seat locks.
