Welcome Guest! If you are already a member of the BMW MOA, please log in to the forum in the upper right hand corner of this page. Check "Remember Me?" if you wish to stay logged in.
We hope you enjoy the excellent technical knowledge, event information and discussions that the BMWMOA forum provides.
Why not take the time to join the club, so you can enjoy posting on
the forum, the club magazine, and all of the discounts and benefits the BMWMOA offers?Want to read the MOA monthly magazine for free? Take a 3-month test ride of the magazine; check here for details.
NOTE. Some content will be hidden from you. If you want to view all content, you must register for the forum if you are not a member, or if a member, you must be logged in.
If you're referring to changing the key/tumbler portion of the latch, take a look at this. The process takes longer to explain than to do: http://www.ibmwr.org/ktech/topcasekey.shtml
I was able to remove the lock assembly by pushing in the end detent spring on the end of lock. But now I'm unable to reinsert the lock assembly due to the spring not letting it in all the way. And to top it off my computer has a bug and unable to do much on it. Computer going into the shop Monday. Thanks for the help.
PS it's the R side case latch on the K1100LT
The latch hole has four slots. Start the lock cylinder with the locking tab in the slot that is at 3 o'clock. Push all the way in then rotate counterclockwise until it stops.
Trip computer? FI computer? What's it doing/not doing?
(I reread your post. If your talking home computer, we can't help you here. We all can barely post, email, and use ebay).
98lee,
Thanks...... Yes, pictures worth 4 thousands words. With the help of pictures AND a liberal amount of grease, along with a COUNTERclockwise rotation, lock cylinder popped into place. I'm good to go.
10-4 on (home) computer knowledge. In my case, lack of.
