Results 1 to 9 of 9
Thread: Removing lock - Integral Cases and Rekeying Locks
    Apr 2005
    Western New York State
    The latch on my "94" K1100LT side case broke and I have the replacement latch. How do you remove and replace the lock? Tried a search with no luck.
    Registered User 6322's Avatar
    Mar 2012
    Riggins, ID
    If you're referring to changing the key/tumbler portion of the latch, take a look at this. The process takes longer to explain than to do:
    http://www.ibmwr.org/ktech/topcasekey.shtml
    Gary Phillips - #6322
    '77 R100/7 Dirt Hack, '83 R80ST, '85 K100RS w/EML, '93 K1100LT, '00 R1100RS
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    1der,
    I added "Integral Cases" to your title to be more specific.
    "A picture is worth a thousand words" so here are four thousand words plus a few:
    Here is your lock cylinder with the retaining tab protruding. This is what you must push back flush with the cylinder to remove the lock cylinder.
    This is the latch in the open position.
    This is where the retaining tab ends up with the cylinder inserted.
    LONG MAY YOUR BRICK FLY!
    Lee Fulton Forum Moderator
    3 Marakesh Red K75Ss
    Mine, Hers, Spare
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    This is with the cylinder inserted showing the retaining tab in place. Push the tab in, pull on the key to remove cylinder. Some rotation helps.
    To install cylinder, with key in the cylinder, push into the latch rotating COUNTERCLOCKWISE until it is seated and stops rotating.
    Mine, Hers, Spare
    Apr 2005
    I was able to remove the lock assembly by pushing in the end detent spring on the end of lock. But now I'm unable to reinsert the lock assembly due to the spring not letting it in all the way. And to top it off my computer has a bug and unable to do much on it. Computer going into the shop Monday. Thanks for the help.
    PS it's the R side case latch on the K1100LT
    Mansfield,MA
    Nice pictures Lee
    Mod Squad
    2009 F800GS 1994 TW200
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    The latch hole has four slots. Start the lock cylinder with the locking tab in the slot that is at 3 o'clock. Push all the way in then rotate counterclockwise until it stops.
    Trip computer? FI computer? What's it doing/not doing?
    (I reread your post. If your talking home computer, we can't help you here. We all can barely post, email, and use ebay).
    Mine, Hers, Spare
    Apr 2005
    98lee,
    Thanks...... Yes, pictures worth 4 thousands words. With the help of pictures AND a liberal amount of grease, along with a COUNTERclockwise rotation, lock cylinder popped into place. I'm good to go.
    10-4 on (home) computer knowledge. In my case, lack of.
    3 Red Bricks
    Jan 2007
    Pleasanton, Ca.
    Here is the BMW Service Bulletin on removing and rekeying Intergral case locks. The rekeying process is the same for gas cap and seat locks.
    Attached Files Attached Files
    Mine, Hers, Spare
  1. Rekeying Airhead pannier locks
    By gudenuf in forum Airheads
    Last Post: 02-06-2019, 02:44 AM
  2. Removing lock - Integral Cases
    By 1der in forum Flying Brick K-bikes
    Last Post: 10-04-2014, 06:29 PM
  3. K75 rekeying seat lock?
    By barooo in forum Flying Brick K-bikes
    Last Post: 07-11-2009, 01:31 AM
  4. Integral Side bag locks
    By Royalbeemer in forum Airheads
    Last Post: 05-01-2009, 09:10 PM
  5. Rekeying System Cases with pics
    By jimvonbaden in forum Oilheads
    Last Post: 02-05-2007, 11:01 PM
