jimwjarmour
jimmy armour
Hi everyone, I have received a really good used input shaft (older style 1996 I believe) from Motor works in the UK, to replace the old one with the flat type spring in my 2000 r1100rt, what I noticed is on the out put end of the shaft there is no washer between the bearing and the retaining clip ? were there some shafts with only the clip[ as there is no room for a washer on this shaft ? thanks in advance Jimmy
