Results 1 to 12 of 12
Thread: Schuberth E1 visor flop - what's the road fix?
    TravelsWithBarley.com
    Jan 2009
    Craftsbury, Vermont
    It couldn't happen while I was in Des Moines, it had to wait till I was on the road again. Yup, the visor flops down at 20mph which is a bear in humid heat. Short of duct taping it up, is there a McGuyver fix I can use till I get home in a week?
    Pete and Glenlivet on the road in West Virginia
    '18 R1200GSA and '12 R1200GSA for solo rides
    '10 R1200GSA with Hannigan sidecar for rides with Glenlivet
    '15 Honda CRF250L for exploring places I'm afraid to take the big GSA!
    http://travelswithbarley.com/
    Liaison 20774's Avatar
    I'm not exactly familiar with the helmet but found this idea:
    https://forums.bmwmoa.org/showthread...l=1#post946568
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    This has been a problem with my C3 and Annie’s Women’s C3 Pro. Back at the Salem Rally the Schuberth stall was installing a fix; it was not completely successful. The way I fixed our helmets was to place a rubber fender washer under the visor at one of the pivot points. One washer on one side has fixed our problems, but you could use one on each side. If you look at the pivot points you will see a circular area on the underside of the visor. You are looking for a rubber washer that will fit in that circle. The washers are available at hardware or home improvement stores and come in a variety of diameters and thicknesses. You should get a few of different thicknesses to see which works best. I’ve found that the thinner ones generally do the job.
    Kevin Huddy
    Tm Pterodactyl MT Outpost
    Jul 2007
    Quote Originally Posted by akbeemer View Post
    Ha!!! I moved on from the o’ring to the washer... it works better.
    Kevin Huddy
    Central Ohio
    The O-ring worked pretty well on my C3, though I tried a couple different thicknesses. Besides the O-ring, some C3 owners used the felt pads intended for chair legs to prevent floor scratching. Basically, you want more friction at the pivot. Perhaps you can find a rubber band that would work? Have an extra foam earplug you could cut up?
    Larry
    2006 R1200RT
    Feb 2010
    Cape Cod, MA
    It looks like Revzilla sells a E1 Visor mechanism for $25, but they do not show a picture of what it looks like.I also can not believe that you would have to hack fix a helmet that looks like it cost $400-$800! Good luck and I will think twice before shelling out that kind of $$ on a helmet.
    John Simonds
    2017 R 1200 GS Adventure
    1975 Norton Commando 850 Roadster Mk 3
    If it ain't broke, fix it 'till it is.
    Jan 2009
    Craftsbury, Vermont
    Thanks for the feedback, folks. I'm finally in a town big enough to have a well-stocked hardware store. Will start hunting.
    Jan 2016
    Central Illinois
    Well Stocked Hardware Store
    Quote Originally Posted by glenfiddich View Post
    A well stocked hardware store is kind of a oxymoron these days
    You could make a small braid out of Glenlivet's tail hair to tighten up the pivot point.
    I noticed mine got a little floppy on the way home too Pete. Travel safe, we’ll have to put that finger of scotch on hold until we get together again.
    R. Reece Mullins Ebony R1200RT (Gretchen)
    MOA # 143779
    MOA Charter Club #5 #364 #100
    BMW MOA Vice President
    May 2017
    Evansville, Indiana
    If you carry the disposable foam earplugs, you can jam them in between the helmet and the visor near the pivots. The Visor is either all up or all down, though.Name:  earplug fix.jpg
Size:  52.8 KBName:  earplug fix 2.jpg
    Jan 2009
    Craftsbury, Vermont
    Quote Originally Posted by astros50 View Post
    LOL! I was in a hurry to get ahead of the rain so I crammed a couple McDonald's fries under the visor. They lasted 200 miles and Glenlivet cleaned up the residue. Earplugs would have been a better fix!
    May 2017
    Evansville, Indiana
    Brilliant fix! Although I don't envy the task you had cleaning the fry residue. I am glad you had such an excellent riding partner willing to help you.
    I have been following Glenlivet's and your journey on Facebook. Thanks for the photos. They are an fine example of what Facebook can and should be.
  1. Replies: 22
    Last Post: 05-12-2016, 04:30 PM
  2. Visor wipes for road trips?
    By drj434343 in forum Oilheads
    Last Post: 09-14-2015, 03:11 AM
  3. T3 Visor
    By ROGSLATER in forum Gear
    Last Post: 11-25-2010, 01:00 AM
  4. Schuberth Sun Visor
    By burnszilla in forum Gear
    Last Post: 04-26-2006, 04:16 AM
