Results 1 to 8 of 8
Thread: R1200R Puig hugger breakage (and repair)
    Just another rider
    Wisconsin
    R1200R Puig hugger breakage (and repair question)
    Recently got back from an Alaska trip on my R1200R (21 days, ~8K miles). While washing the accumulated crud off the bike I noticed the rear mounting bracket for the Puig hugger had broken.
    It looks to me that all it is, is just pot metal; my guess is JB Weld (or equivalent) will work. If anyone has another (better) suggestion please pipe up. TIA!
    MOA #24991 Pauls1150's Avatar
    south of Los Angeles
    If you just butt the pieces together, it'll break again pretty quickly.
    Create a hard metal sleeve long enough to cover the break and then some more, with just a "slip-on" clearance fit, and then put the JB all over inside everything (including the butt join). Oughta work.
    Judging by how it's hanging in the pic, you may want to reexamine the overall mounting & angles...
    Just another rider
    Wisconsin
    Thanks for the reinforcing tip! I'll give that a try. Looks like I gotta find a beer can to cut open, now where could I get one of those... ?
    For the photo I spread the two pieces apart to emphasize the break. The whole part is designed (or at least it's supposed to) pivot with the swingarm/driveshaft. When reattached the two parts match up perfectly.
    A beer can would probably be too soft; maybe a piece cut from an actual "tin" (soup) can, or a piece of hard flashing?
    Or maybe even weld the silly thang...
    Just another rider
    Wisconsin
    Actual real welding is more than this thing is worth. I'll try using some alum flashing I have *somewhere* in the garage.
    I'm off on another road trip (taking the R1200RT this time) so this repair will have to wait for next week.
    Registered User dirtmerchant's Avatar
    Feb 2006
    Southwest Florida
    Have you contacted Puig about it? They may replace it, looks to me like it shouldn't have broken unless it took a pretty good hit...
    Mansfield,MA
    Perhaps- https://www.amazon.com/FiberFix-Repa.../dp/B00B297WDG
    I’ve never used it but have seen the end results, and they looked pretty good.
    Mod Squad
    2009 F800GS 1994 TW200
    Douglas Williams
    Mar 2006
    Raleigh, NC
    Same trip(2017), same hugger, same problem. JBWeld seems to be working well so far.
    Doug
    Sent from a Galaxy, far, far away
  1. Powerlet in Puig, Now What?
    By bikeflyer in forum Wetheads
    Last Post: 03-24-2017, 04:17 AM
  2. R1200R headlight lens repair
    By tinkertoy in forum Hexheads/Camheads
    Last Post: 07-29-2015, 04:09 AM
  3. 2008 R1200R rear hugger install clearance
    By OLDPILOT in forum Hexheads/Camheads
    Last Post: 06-23-2013, 08:17 PM
  4. 2007 R1200R ABS repair
    By fletchdude in forum Hexheads/Camheads
    Last Post: 02-03-2013, 01:55 AM
