Results 1 to 15 of 27
Thread: 1994 K75S Z Hose Question
    Well I have been into the bike replacing rubber bits here and there. Just did a O Rings change in the starter, Alternator Monkey Nuts etc. etc. etc. I also found a tear in the Z hose. It ripped apart when I removed it. A new one is on the way. I cranked the bike over after putting it all back together again just to hear if the starter and alternator were ok. I had no Z hose installed. The bike starts but will not run.
    So my question is one of better understanding what the Z Hose actually does and how that little hose can prevent the motor from running ?? IMPORTANT little hose
    Expect The Unexpected
    It will not run without the Crankcase vent hose (Z hose).
    The Crankcase vent hose does what its name implies. It vents the crankcase (into the intake plenum).
    It vents it into the plenum above the throttle bodies AFTER THE AIR FLOW METER. Any air that gets into the plenum is unmetered air, meaning that the computer does not know it is there and does not inject enough fuel to compensate for it. Therefore, the mixture is way too lean to properly run. A similar situation will happen if you have the hose in place and remove the oil filler cap (happens on most modern cars too).
    SMALL cracks in that hose will lean out the mixture enough to cause a multitude of problems (poor idle, burned valves, etc.) and that hose is VERY thin and in the hottest part of the bike. The cracks will happen just below the upper hose clamp and just above the lower hose clamp. These hoses usually require changing every couple years but need to be checked WAY more often ( at LEAST once a year).
    Thank you Lee for your detailed response to my question. I understand now and will definitely check the hose every year from here on out
    South Carolina
    Thats good info...
    AKA SNAPGADGET
    Aug 2012
    Hey Lee,
    Mine has cracks in it. Do you have a part number?
    Lynn
    MOA #57883
    11 15 1 460 480 VENT HOSE $15.56
    Apr 2007
    Rockport, TX
    Quote Originally Posted by ARGENT BRICK View Post
    Hey Lee,
    Hey, Lynn; that might be part of the reason you are getting poor mpg as posted in your other thread.
    Mine was cracked as I discovered a couple months ago during another procedure---when I installed a new Z-hose it made a world of difference!
    ---Jeff
    A thread I started when I changed mine some time ago, with pics and replacement info
    http://forums.bmwmoa.org/showthread.php?t=56654
    A good lesson that these hoses may look fine but should still be changed with some regularity.
    Ted
    1994 K75RT
    Moto Pages
    Aug 2012
    Thanks, Lee.
    My BMW dealer is not that far away from the local VA hospital, and I figured that I would hit both in one trip, or so I thought. I dropped by the dealer to pick up the hose, and, of course, they did not have it in stock. They only keep one in stock and it was sold last week. Just my luck.
    Lynn
    MOA #57883
    Apr 2007
    Rockport, TX
    I hope you ordered one, nonetheless! Among the best purchases one can make.
    ---Jeff
    Aug 2012
    Quote Originally Posted by Zagando View Post
    Yeah, I did. The nice thing was that my dealer did not consider it a special order, so I did not not have to pay for it yet. It just frost my rear end when dealers insist upon payment up front on everything. I can see it on clothing, helmets and such, but not on normal maintenance parts. Especially if it is something that they normally stock.
    I understand why they do it, though.
    A friend of mine who is a service manager suggested that we make one out of fuel line and metal fittings. I wonder, has anyone made their own?
    Lynn
    MOA #57883
    Apr 2007
    Rockport, TX
    Good question, Lynn and I know others have used certain larger diameter rubber hose to replace the Z-hose with---but if fuel line was used it would also have to be larger than the 8x13mm BMW standard. Check the ends for the correct diameter needed; might be in the neighborhood of 18-20mm is my guess.
    Do not try the aftermarket Z-hoses (even the ones Beemerboneyard sells) as 98Lee advises us that they are even more flimsy than the OEM ones (and he is one who really knows of where he speaks).
    But maybe a stout large diameter (truck?) fuel line would work just as well? On the other hand, maybe the Z-shape would require too much sharp bending, thereby cutting off the very pressure that needs to be vented in the first place. Interesting to see what the gurus say about this.
    Don/Paul/Lee/Ted to the nearest white courtesy phone, please!
    ---Jeff
    I think the hardest part of making a more sturdy replacement would be to also make it flexible enough that you could actually install it. There's not a lot of room there for larger diameter hose. That being said, if you can install it (and that's a serious IF) and it doesn't leak, it would work.
    Jul 2007
    Evansville, WI
    I had the airbox eliminator on the 87 S that I owned and I only remember replacing that hose once. I think the eliminator really helped keep that over the engine area cooler, which made the hose last longer. Kind of a stretch for a reason for the eliminator, it did get a lot of looks.
    87 K75S, bought new, now sold
    13 C650GT
    MOA 44606
    Jun 2007
    Well, that $15 is just unfair....the K12RS only has the 'full distribution hose' unit available and the last time I purchased one it ran over $50 and now it runs over $75....usually it is just the Z shaped part that goes, but not always, but it is only available in the whole assembly these days. Still quite hard to replace.
    Jim Douglas '00 K1200RS >138,000 miles -- Black, 01/10/2000 to present
    Gone: White '09 K1300S sold @ 22k mi, Black '93 K1100RS traded @ 78k mi, Red '85 K100RS sold @ 44k mi, '06 Kaw 650R chrome yellow track bike sold http://www.seagullbb.com/
