Results 16 to 17 of 17
Thread: Wethead bodywork Fasteners and washers
    Registered User paddlefoot's Avatar
    Mar 2018
    East TN. Bouncing around
    Anti seize
    Itís a good idea to wipe a little dab of anti seize on the screw threads before you reassemble things. It will cut down on the dissimilar metal corrosion on those fasteners and keep you from having to drill the heads off to get things apart. We deal with this all the time on aircraft where owners want to change the plated screws for stainless, then find out thatís not a perfect world either.
    Mar 2011
    socal
    Iíve dropped or lost a few body panel screws on various bikes over the years
    To prevent mixing the wrong shoulder screws up I use a bit of masking tape to secure each screw next to the correct hole in panel that iíve Removed
    For reassembly I use a dab of white assembly grease on each screw
    Parts manager at Long Beach BMW made me up a kit with the 3 most commonly lost screws and plastic washers, since I got the spares, I havenít lost a screw go figure!
    Jim
  1. Replies: 1
    Last Post: 02-04-2016, 12:48 AM
  2. XR Bodywork Removal
    By bmwroadsterca in forum S1000 - The Hothead
    Last Post: 11-28-2015, 07:30 PM
  3. Wethead Bodywork and Air Filter Video!
    By jimvonbaden in forum Wetheads
    Last Post: 01-09-2015, 06:49 PM
  4. Bodywork on the '09 RT
    By tf78933 in forum Hexheads/Camheads
    Last Post: 12-05-2012, 03:47 PM
  5. K100RS bodywork interchangability
    By CTab in forum Flying Brick K-bikes
    Last Post: 09-29-2003, 09:06 PM
