Results 1 to 4 of 4
Thread: 1996 K1100LT radio
    May 2004
    boise, idaho
    1996 K1100LT radio
    My new-to-me 1996 K1100LT has what is probably a serviceable radio, but I don't know the anti-theft code. I believe the code is recoverable with BMW's help, but I'll need a radio chassis number. Therein lies the problem. I don't know how to remove the radio. The on-line manual shows a OEM tool that apparently shipped with the bike. It appears to be two wires whose ends are passed down between the radio and its carrier. However, the illustration is none too clear. Can someone who has this tool describe it in enough detail so I might make a suitable one myself? TIA
    MOA #24991 Pauls1150's Avatar
    Apr 2008
    south of Los Angeles
    Dunno about the K1100s specifically, but with my K100LT, the "special tool" was a U-shaped piece of springy metal, maybe 6 inches long and about 2 inches wide. I couldn't find it on the MAX fiche.
    To pull my radio, the tool was inserted into the two little holes on the side of the radio, then pressed (and slightly squeezed? don't remember) to release the clips that hold it down.
    Maybe two pieces of coat hangar would work as well?
    In the Boise area - Big Twin should be able to help, or maybe save a few bucks and contact Mitch http://www.mitchsmotorcycles.com/
    May 2004
    boise, idaho
    K1100lt radio
    Thanks for that info. I'd reviewed the info in the radio manual online (as mentioned above) but thought the wire/tool has some sort of cut away or knob on it's ends. I'll try to make one with just straight ends and see how it works.
    I'd previously contacted both Big Twin and BMW customer service, but wasn't able to get very far with that approach. Mitch is WAY beyond my budget.
    Sometimes ya just need the versatility of the owner's forum!
    I think that the K-bikes are now old enough that service technicians that have experience with them are a little thin on the ground. Old airheads have an amazing support group, but the K-bike owner may face greater challenges.
    Thanks again for your response.
    Jan 2005
    Sioux City, Iowa
    That tool was used on many radios that had DIN face plates. Any radio installer could pull that for you easily. Most retailers of after market radios should have that tool available.
    Chuck Swenson
    MOA # 9162
    2010 R1200RT, 2003 F650cs (BMW #12 & 13)
  1. 1996 K1100LT fork strip
    By walt3022 in forum Flying Brick K-bikes
    Last Post: 06-20-2018, 09:42 PM
  2. Oil/Water Pump Rebuild - 1996 K1100LT
    By davidbufo in forum Flying Brick K-bikes
    Last Post: 02-16-2014, 03:36 PM
  3. 1996 k1100lt purchase
    By ghyber in forum Flying Brick K-bikes
    Last Post: 06-18-2009, 02:39 PM
