Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 46 to 60 of 71
Thread: Motorcycle Dolly
  1. #46
    Jul 2015
    Los Angeles, CA
    Quote Originally Posted by khittner View Post
    Could be, Kurt, but now that I look around a bit at industrial suppliers, the money and load capacity in these widgets seem to be in the casters.
    I doubt that Park‒n‒Move would use the thicker, more expensive, steel that they use for their base if it wasn't at least PART of the reason that they have an 1,100 pound weight rating. I doubt that it's just the casters.
    The knock-off's thinner stamped steel plate doesn't bend under the weight of the RT
    I'd bet it does bend, or at least flexes. Such flex puts the cheap casters on edge (or at least applies excess pressure to the inner edge of the wheel) so the weight is no longer spread out all the way across the wheel, making it harder to move the bike around. Particularly if, as you have done, the user exceeds the recommended weight capacity.
    but it looks like one can (and probably has to) spend pretty good money for small-diameter, high-weight-capacity, stem casters.
    That would explain the higher cost of the original Park‒n‒Move over the knockoff, and the reason that it moves across less‒smooth surfaces easily.
  2. #47
    SURVIVOR akbeemer's Avatar
    Jul 2007
    Silver City, Montana
    Good grief..... give it a rest!
    Kevin Huddy
    Tm Pterodactyl's MT Outpost
    2017 R1200GSA & 2013 FJR
  3. #48
    gig harborr ,wa
  4. #49
    RK Ryder
    London, Ontario
    Please.
    Paul
    Niagara Riders & Knights of the Roundel #333
    volunteers@bmwmoa.org
  5. #50
    The price differential is the key here. You won't get for $72 dollars what you get for $200. Don't expect it. It almost always won't happen.
    Whichever one you own, if you are happy with it I'm happy for you.
    On a similar note I happen to have and use a Handy Air Lift I bought as part of a group purchase with a dealership and a few others maybe 20 years ago. Today, with its actually usable wheel chock it costs almost three times what the fairly popular Harbor Freight lift costs. Add the side panels so I can ride on and off and the price is even higher. What would I do in today's market? I'm not sure but would probably still buy the lift from Handy Industries because I know it has been totally reliable with no maintenance or repairs for 20 years. YMMV
  6. #51
    Jul 2015
    Los Angeles, CA
    Quote Originally Posted by EUGENE View Post
    Quote Originally Posted by Paul_F View Post
    Please.
    Slam the person who points out that misleading information has been posted. Say nothing to or about the person who posted it and has not accepted responsibility for doing so. What's wrong with this picture?
  7. #52
    Jul 2015
    Los Angeles, CA
    Could not agree more.
    I'm very happy with my authentic Park‒n‒Move. One member, who uses the knock off apparently isn't. A couple of others who say that they also have the Park‒n‒Move say that they are not happy with theirs. But it's not clear if they have the authentic model or the knockoff. I've asked, but so far, none have responded.
  8. #53
    Aug 2014
    Lakeland,FL
    Saw these mentioned in another thread and they looked interesting.
    https://www.dynamotousa.com/
  9. #54
    Mansfield,MA
    Quote Originally Posted by mikegalbicka View Post
    Two sets of wheels, one for the front and one for the back, does look interesting.
    Not sure about the real wheel pick-up point. I would like to see one in person.
    I still lead towards this design due to its 3-point contact and connected two sets of wheels-
    Although If I was to buy or build one, I would like to see the "carry" wheels a large as possible so the 1/4X20 nut I dropped weeks ago didn't bring everything to a screeching halt
    Mod Squad
    2009 F800GS 1994 TW200
  10. #55
    Jul 2015
    Los Angeles, CA
    A member here reviewed this device about a year ago. He liked it. But there were no comments from other members. This user says that he "was not entirely happy with using the Legal Speeding Park'n Move," but it's possible that he too got the knockoff. He may have been fooled as was one other member in this thread.
    One thing he liked was that it "… does not take up space when not in use. Other devices would have required using either the side stand, or the device took up too much space when not in use, or required me to push or ride the R1200RT onto the device." Actually these stands take up more than twice as much space as the Park‒n‒Move to store. The Park‒n‒Move does not require either riding or pushing onto it.
    I looked at these before purchasing my Park‒n‒Move. The first objection was the price. The cost of this thing is nearly 3X the cost of the Park‒n‒Move and if one gets a different bike, chances are that a new part, costing $65 may be necessary.
    The rear device requires that after you raise the bike on it, you attach another part to keep the bike from rolling off the stand. One member here objects to the extra step that I use to secure the Park‒n‒Move, a ratchet strap, saying that it's a PITA. This is much the same. AND it requires that you put both the front and rear wheel onto separate stands. Would these "extra steps" also be a PITA with this device?
    I wondered how well it would hold up after a couple of years of use? The floor/ground is a gritty place and I can't tell if there are any seals to prevent grit from getting into the bearing surfaces. Probably the use of a power washer would drive out any grit that got into them. My Park‒n‒Move has been in use, outside for three years, with the afore mentioned gardeners blowing debris around it once a week, not to mention the regular movement of grit caused by the wind. It's still going strong.
    One will need to purchase another device to support the bike if one wants to remove the front wheel. Not necessary with the Park‒n‒Move where either wheel can be removed. It looks as if rear wheel removal can be accomplished with some iterations of the device. With some others, it can't be.
    Despite claims to the contrary, I think there will be issues moving the bike on rough surfaces. Based on the size of the wheels it looks as if the device will roll over even sizeable cracks or debris on the ground surface if moving the bike forward. But if moving the bike sideways, the wheels are very small and looks as if they'll get caught in cracks in the cement. I doubt that it would move sideways at all on my paving‒stone‒parking‒pad, where the Park‒n‒Move moves easily. The video shows it easily moving across concrete expansion joints but it only shows the rear sideway wheel which has three rows of wheels. The one supporting the front end only has two rows of wheels. It also only shows them moving across these joints at an angle, rather than straight across them, so I'd guess that care needs to be taken there. HERE'S a link to their video. The video shows it 'hanging up' on a pair of pliers but I doubt that any of these devices would fare any better against such a large obstruction.
    There is no shortage of "reviews" on this stand but most of them are either 'puff pieces' or just a notation that they exist.
    These stands are very elegant and there's quite a lot to be said for that. But the price and the fact that it does not allow for working on, or removal of the front wheel, are off‒putting for me.
  11. #56
    '99 '03 '06 National Co-Rally Chair Friedle's Avatar
    Poughkeepsie, NY
    beemerdood…………….you need to spend more time RIDING your bike and less time worrying about how it is parked....or how others park their bike. You're getting way too anal about this. Give it a rest FGS !
    Friedle
    Ride fast safely
  12. #57
    Liaison 20774's Avatar
  13. #58
    Pismo Beach, CA
    I just went out to the lobby, they're out of popcorn. . .. .
    Lew Morris
    1973 R75/5 - original owner
    1963 Dnepr
  14. #59
    But I see some juju beans in the other counter!
    Maybe the next movie will be about tires, oil, air pressures...
  15. #60
    There’s a spectrum of other snack options.
  1. Redline Motorcycle Dolly "junk"
    By blackbeauty in forum Gear
    Last Post: 09-14-2015, 11:12 PM
  2. Motorcycle dolly?
    By bobframe in forum Gear
    Last Post: 03-24-2013, 10:51 PM
  3. hello dolly
    By f14rio in forum Motorrad
    Last Post: 03-02-2013, 12:18 AM
  4. hello, dolly
    Last Post: 11-19-2012, 12:10 AM
