Today while riding on the Blue Ridge Parkway,my friend's S1000xr 2017 started acting strangely.
The engine will not shut off when the key is at the off position.
It will only shut off with the kill switch
It will also start even if the key is not in the ignition
The odometer readout is flashing in the display
I did an autoscan with my GS911 and got only one fault code that I cannot clear
1 fault codes found:
B7F604 Mileage incorrect (tamper detection)
The fault is currently present.
The Gs911 reports that the key is key 1 and is valid and enabled.
Any ideas?
