Results 1 to 8 of 8
Thread: '88 K75C Where does this negative battery cable go?
    Registered User rall275's Avatar
    Apr 2017
    Harrisburg, IL
    Guys, I did a clutch spline lube and other maintenance items on my 88 K75C and I'm reinstalling the battery and I can't find where the large cable on the negative terminal goes. In the photo, the top wire is for my battery tender. The middle sized wire is the ground wire connected to the left side of engine. The larger cable goes leftward from the negative terminal, but I can't figure where it terminates. Any clues? I took copious photos, but not copiously enough apparently.
    My positive has a battery tender wire and the cable going to the alternator.
    Thanks guys
    13278
    Near Lynchburg, VA
    Battery ground is on the left side of the transmission.
    Apr 2017
    Harrisburg, IL
    The yellow highlighted cable
    For clarification, I highlighted this unknown cable in yellow.
    Early Ks (including yours) came with one undersized ground wire that attached to the bolt on the transmission just above the shift lever pivot. When the abs bikes came out and with the proliferation of heated gear, they realized that they needed more capacity, so they just doubled up the ground wires.
    Some previous owner has added that larger wire. It should hook to the same place as the other ground wire.
    One thing I also like to do, in the name of redundancy and better grounds, is run a #12 wire from the ground bolt on the transmission to the ground bolt on the frame under the gas tank.
    Apr 2017
    Harrisburg, IL
    Thanks for your response. Weird thing is I don't remember removing this from the left side ground location. I'm almost wondering if it was not attached but tucked over there since this is the first I've accessed the battery.
    Is the wire the same length (within an inch or so) as the one going to the bolt on the transmission? If so, that's even more indication that that is where it originally went.
    Apr 2017
    Harrisburg, IL
    I'll check length. And, while at it, I'll look at the bends in the wire to see if that might hold a clue.
    Thanks!
    Apr 2017
    Harrisburg, IL
    Length is almost same, the 2 also have bends nearly identical, so I'm convinced it is an additional ground cable. Normally my memory is solid, maybe I'll have to admit to getting older.
    Thanks! The bike project continues
  1. Battery, 86 K75C
    By NateVentura in forum Flying Brick K-bikes
    Last Post: 11-14-2010, 12:14 AM
  2. Problem with the negative lead on my battery
    By scootrp125x in forum Oilheads
    Last Post: 10-31-2008, 02:54 PM
  3. Replacement Battery:'87 K75C
    By st3ryder in forum Flying Brick K-bikes
    Last Post: 05-26-2007, 02:51 AM
  4. K75C Throttle Cable Replacement Questions
    By JimMoore in forum Flying Brick K-bikes
    Last Post: 04-25-2007, 05:28 PM
  5. K75C clutch cable part number
    By hgantz in forum Flying Brick K-bikes
    Last Post: 04-20-2007, 07:49 PM
