Results 1 to 2 of 2
Thread: What does this breather hole connect to?
    Jun 2007
    Portsmouth, NH
    As you can see, I have some oil weeping from this hole. It's location close to the oil filler would make it seem like the breather hole connects to the crankcase, but it would seem foolish for there to be an open hole into the oil supply. Anyone know what's on the other side of this hole?
    Liaison 20774's Avatar
    It's a drain for the upper part of the starter cavity. If oil is seeping out there, the tubes that carry oil mist from the breather to the carbs have become disconnected or cracked. You'll need to pull the stater cover and investigate.
  1. Replies: 1
    Last Post: 05-18-2017, 12:17 PM
  2. Connect Radio to Bluetooth
    By COULTER in forum Hexheads/Camheads
    Last Post: 08-10-2014, 09:31 AM
  3. Spot connect
    By soph9 in forum Gear
    Last Post: 03-06-2011, 11:40 PM
  4. OK where does this connect to???
    By RJM2096 in forum Oilheads
    Last Post: 03-07-2008, 10:33 PM
  5. Where to Connect
    By PAULBACH in forum Gear
    Last Post: 04-28-2007, 10:50 PM
