Results 1 to 6 of 6
Thread: Right Head Kerblammo? (04 R1150R)
    Engine with 37k miles developed an oil leak from the right cylinder head spark plug recess. I pulled the valve cover and found this... has anyone seen this before? The photos are looking directly into the spark plug recess. You can see the top of the plug in the middle of the picture. The (apparently) damaged section is arrowed. The engine is running ok, I only looked because it was leaking oil.
    Registered User RIDERR1150GSADV's Avatar
    Apr 2017
    S.Florida
    That is normal. All you need to do is replace the rubber seals as they likely hardened up due to age. Look at the other side of the engine and you’ll see the same. The trick to sealing up the engine after a valve adjustment is to rotate that seal 90 degrees every time. This allows for the seal to reset itself so to speak..
    MOA # 108516
    Current ride 2017 R1200RT White
    Past rides '04 R1150RT, '05 K1200LT, '06 R1150GSA
    Nibley, UT USA
    Given the low cost of the rubber donuts on the center spud of the oilheads, I always just replaced mine at every service. It makes sense to re-use the cover gasket as they are spendy and designed for multiple re-use, but the donuts...not so much. IMHO, of course.
    Best,
    DG
    DGerber
    1983 R80ST — 1984 R80 G/S PD — 1993 R100GS — 2004 K1200GT w/Hannigan S/C — 2010 K1300GT
    Apr 2017
    S.Florida
    I had 90K miles on my oil head and never replaced them as they were fine by rotating them. I only had that bike for 4 years though...
    The OP’s bike is an ‘04 and is suspect they were never replaced..
    MOA # 108516
    Thanks for the feedback. I am amazed that this is normal... the part in question looks like a neanderthal took a bite out of it. Interestingly, I replaced the valve cover gasket and "donut" when I checked the valves about 1k miles ago. I rechecked valve clearances a few hundred miles later, did not know to rotate the donut. Will do so, thanks again.
    Apr 2017
    S.Florida
    You’re welcome! I remember having a similar reaction to yours when I first opened up the motor to adjust the valves..
    MOA # 108516
  1. Replies: 6
    Last Post: 08-23-2017, 01:41 PM
  2. 2002 R1150R - Steering Head Bolt Size?
    By shropdog in forum Oilheads
    Last Post: 10-25-2016, 08:04 PM
  3. Replies: 17
    Last Post: 05-30-2012, 09:14 PM
  4. Locked Steering head on 04' R1150R
    By bmwgsrider in forum Oilheads
    Last Post: 04-18-2009, 12:39 PM
  5. R1150R or R1150R Rockster 80th Anniversary?
    By kromedome in forum Oilheads
    Last Post: 02-26-2005, 03:57 PM
