Results 1 to 5 of 5
Thread: Stick coil connector 2012 R1200RT
    My bike seemed to run fine , but idle was a little rough and the was a slight knocking between 3000 a 4000 rpms.
    I read threads on checking stick coils and decided to give it a try. what I found was the left side connect was damaged , it appears that there was arcing in the connector and burnt the plastic casing away.
    Any one have this problem and what is the best way to fix it?
    I am waiting for the dealer to open soon.
    The wire is part of the wiring harness and not a short replaceable section.
    Theunis
    Theunis
    Chilliwack B.C
    2012 R1200RT
    Central Ohio
    Your dealer will probably fix you up with this repair connection:
    You'll want to solder and heat-shrink the leads onto your harness.
    Screen capture from Max BMW fiche.
    Larry
    2006 R1200RT
    Quote Originally Posted by lkraus View Post
    Thanks Larry
    I have ordered 2 repair connectors from the dealer , I will change both sides as the bike has 200K kms .
    Theunis
    Chilliwack B.C
    2012 R1200RT
    Jun 2009
    Rochester, MN
    I had the same problem when I went to change my spark plugs on my newly-acquired '07 RT. I was able to source the replacement just as you have. I would also look at your actual stick coil, sometimes the plastic holder (u-shaped) is also cracked, allowing the connection to flex.
    I have now learned that you should remove the connector first before removing the coil. I wished the previous owners had learned it before I got the bike!
    1995 BMW K75s - 100k and climbing!
    2007 BMW R1200RT - 62k
    2009 BMW G650GS - 22k and ready for Alaska!
    Well finally got the connectors repaired. Bike runs better , throttle is much smoother too.
    All seems good.
    Before changing coils check the connectors first, cheaper to repair.
    Theunis
    Chilliwack B.C
    2012 R1200RT
  1. stick coil loose
    By dpmonk in forum Hexheads/Camheads
    Last Post: 11-09-2017, 03:31 PM
  2. Stick coil price
    By dj19343 in forum Oilheads
    Last Post: 09-24-2013, 07:59 PM
  3. New Stick coil time?
    By boxwrench in forum Oilheads
    Last Post: 10-07-2011, 01:41 AM
  4. Stick coil help!!
    By CharlieAllnutt in forum Oilheads
    Last Post: 04-09-2011, 11:31 PM
  5. Stick coil issues...???
    By ND4SPD68 in forum Oilheads
    Last Post: 05-19-2009, 04:14 PM
